    Understanding Endstop and Z Probe
    Using Duet Controllers
    duet 3 mainboard 6hc expansion 1xd z probe endstops
    1.9k
    • SignPostManundefined
      SignPostMan
      I am using a Duet 3 with 3 expansion boards for each of my stepper drivers. I sure this is a newbie question but I don't understand the relationship of the Z Endstop and the Z-Probe. When I configure my endstops to the expansion boards I can get the Printer to home X,Y and Z no problem. When I try to run mesh bed I get G29 Mesh Level Compensation, I get Error: Z probe already triggered before probing move started. I am using a simple microswitch for the Z Probe
      I am also not sure the relationship of the Z probe type and switch and the Z endstop. How is the Input Pin and Modulation Pin used?
      M574 X1 S1 P"!^40.io1.in" ; configure active-high endstop for low end on X via pin !^40.io1.in
      M574 Y1 S1 P"!^42.io1.in" ; configure active-high endstop for low end on Y via pin !^41.io1.in
      M574 Z1 S1 P"!^43.io1.in" ; configure active-high endstop for low end on Z via pin !^43.io1.in
      M558 P5 C"io5.in" H10 F120 T6000 ; set Z probe type to switch and the dive height + speeds
      ;M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:2300 Y15:1300 S200 ; define mesh grid
      • fcwiltundefined
        fcwilt @SignPostMan
        @signpostman
        What boards are you using?
        A Z Endstop is totally separate from a Z Probe.
        When using a simple switch as a Z Probe you don't have a modulation pin, just an input pin.
        If the probe is being reported as active at the start of a probe just change C"io5.in" to C"!io5.in" to invert the signal.
        • kb58undefined
          kb58
          Yup. If it's reporting "active" when enabled, it means that the switch is already in the "active" state (defined by you as a high or low signal), when the sensor was enabled. It's either what fcwilt said above, or it could be a shorted or open switch, depending how it's wired.
          If there's some question of what the switch is doing, unplug it from the controller board and put an ohmmeter/continuity tester on the connector leading to the switch. It'll either be shorted or open. Now activate the switch, and it should go to the opposite state. If it does, there's nothing wrong with the switch or cable, so the question becomes: is the voltage level being fed to the controller board what's expected by how you have it configured?
          Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
            SignPostMan
            I actually have the Z Switch attached to the 43.io1.in . and there is nothing attached to the io5.in pin. but without a pin in the Z probe M558 the printer would not home.
            jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @SignPostMan
              @signpostman then you have it configured incorrectly.
              remove the line
              and edit M558 to include the correct pin
              edit your homing files to use G30 for Z rather than G1 H1
              fcwiltundefined SignPostManundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @SignPostMan
                @signpostman said in Understanding Endstop and Z Probe:
                Do you a switch for your Z Endstop and another switch for you Z Probe?
                • fcwiltundefined
                  fcwilt @jay_s_uk
                  @jay_s_uk said in Understanding Endstop and Z Probe:
                  remove the line
                  Unless he has both a Z Endstop switch and a Z Probe switch.
                  I always include a Z Endstop sensor on my printers as it leads to faster homing and simpler homing code.
                    jay_s_uk @fcwilt
                    @fcwilt whereas none of my prints (except the delta of course) have a z endstop.
                    but he did already say he had nothing connected to io5
                      SignPostMan @jay_s_uk
                      @jay_s_uk Looks like I cannot attach Z probe to the M558 only Z probes 8 and 9 are supported on expansion boards
                        @signpostman P8 is fine as a replacement for P5
                          SignPostMan
                          Thanks everyone for your input!
                          I think I got it.
                          I removed the Z-Probe pin, and it now works completely.
