Dudes of flexible socket configuration
With firmware v3. X, the use of Duet is much more flexible, being able to change the use of shockets... But what are the limits? Can you use a shockets that is input, like the one on the temperature sensors, as output, in my case control a fan? Can you make such assignments
@peirof in general you can't use inputs as outputs on Duets because of the protection circuitry. On the Duet 3 MB6HC you can use IO_OUT ports as inputs, but not on the Duet 3 Mini.
