    How to reflash internal firmware
    Using Duet Controllers
    • maroonds
      maroonds last edited by
      Hi where can I find the internal firmware of my duet maestro to download?
        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
        If that doesn't help, can you be more specific?
        maroonds 1 Reply Last reply Reply Quote 0
        • maroonds
          maroonds @Phaedrux last edited by
          @phaedrux It says that I need the firmware binary file for bossa but where do I get it?
            Apparently you didn't read the NOTES BEFORE YOU START section.
            Check that you have downloaded the correct firmware before installing it. See section below regarding which files are needed for each board.
            You'd want this one by the way
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetMaestroFirmware.bin
            And you'll also want to update the DWC files in the /www folder on the SD card since you're doing this manually.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWebControl-SD.zip
            Extract that zip file into the /www folder replacing the contents that are already there.
            Once you have updated and connected to DWC, you should verify that the firmware and DWC were updated.
            Then to ensure you have all the correct files in place you should upload this zip file to the system tab. This would be the normal way to update when you still have a network connection to DWC active.
