Duet 3 mini 5+ wifi phantom SBC. Can't use networking.
@phaedrux for the pc connected its a surface go, however I have also used this same surface to boot up rrf on a duet before so i dont believe that to be the problem. ive re formated the sd card, and tried a new one. I have a strange suspicion for what ever reason its not properly flashing the new firmware and using what ever came on it. not sure how that could happen though
And you've used this method to update the firmware?
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
What version does it report when you send M115?
@phaedrux doing M115 shows FIRMWARE_VERSION: 3.2-beta3.2+1 ELECTRONICS: Duet 3 Mini5plus WiFi im guessing i should update this. on a side(ish) note, were is the erase jumper on the board? i cant seem to find it on both the board and the wiring diagram online.
@no-one-special nvm, i see you just double press the reset button haha, thats simple
@phaedrux just updated to 3.4 beta 3. sadly still the same issue (and it does say using m115 thats its 3.4 beta 3) might it be a problem with the online configurator? or something ive done?
@no-one-special (just to show im not crazy)
And there is nothing plugged into the SBC connector on the board?
@phaedrux nope, nothing connected. Its super strange whats happening
@no-one-special just tried with another duet 3 mini 5+ i have. its working fine, even running 3.2 beta so thats even more troubling.
@no-one-special my guess is that there is a problem with the SD card socket. Please email warranty@duet3d.com with a link to this thread.
