No homing with mechanicel Endswitch
Hey folks,
I'm new to this forum and trying to solve a problem I'm in for a while now.
I try to construct a 4-axis-printer and try to home the 4th axis with an endswitch instead of stall detection like the other axis.Even though M119 reports "U: at max endstop" when I feed positive into the endstop, it doesn't stop and crunches into stall until the movement completed.
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S3 ; configure sensorless endstop for low end on Y
M574 Z1 S3 ; configure sensorless endstop for low end on Z
M574 U2 S1 P"!io3.in" ; configure NC-Endstop for U-Axis on low endAre there any recommendations? Stall detection worked fine.
Much thanks in advance!
@domenili said in No homing with mechanicel Endswitch:
Try this:
M574 U2 S1 P"^io3.in"
@domenili Please post your firmware version (send M115 and post response), your full config.g (so we can see how the axes are mapped) and the homing file that causes the behaviour (eg homeall.g).
Do you mean when you press the endstop switch? Does it report "U: not stopped" when you let go of the endstop?
@fcwilt said in No homing with mechanicel Endswitch:
No. As @dc42 has said many times (eg https://forum.duet3d.com/post/244186)
Remove the ^ characters. Internal pullup resistors should never be enabled on Duet 3 series electronics.
@droftarts said in No homing with mechanicel Endswitch:
Curious. In that case I'm surprised the firmware doesn't simply ignore it.
It reports "not stopped" when it's not triggered, and "at max enstop when it is". I bought an endstop with an led to verify the right values at sight.
Try this:
It tried that, but the behaviour was exactly reversed.
m115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-05-19b2
Config and homeU are attached. Afaik the definition of the endstops is made in config and the homes just take the configured pins right? Because I made no changes at all to the home-files since I switched the endstop.
I've re-posted your files using the </> tag.
Notice in your U homing file the G1 commands. Lines 7 and 9 should be G1 H1.
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sat Aug 21 2021 19:39:34 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name ; Network M552 P10.0.0.3 S1 ; enable network and set IP address M553 P255.255.255.0 ; set netmask M554 P10.0.0.1 ; set gateway M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S1 ; enable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S0 ; physical drive 0.2 goes backwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M569 P0.4 S1 ; physical drive 0.4 goes forwards M584 X0.0 Y0.1 Z0.2 E0.3 U0.4 ; set drive mapping M350 X16 Y16 Z16 E16 U16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E420.00 U44.444444444 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 U12000 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 U3000 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 U800 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 U-52 S1 ; set axis minima M208 X270 Y250 Z350 U52 S0 ; set axis maxima ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"io0.out" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S0.30 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp3 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S0.70 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M302 P1 ; allow cold extrusion ; Endstops M574 X1 S3 ; configure sensorless endstop for low end on X M574 Y1 S3 ; configure sensorless endstop for low end on Y M574 Z1 S3 ; configure sensorless endstop for low end on Z M574 U2 S1 P"!io3.in" ; configure NC-Endstop for U-Axis on low end ; Custom settings are not defined
; homeu.g ; called to home the U axis ; G91 ; relative positioning M913 U10 ; set motor current to 10% G1 H2 Z5 F6000 ; lift Z relative to current position G1 H2 U50 F1500 ; move quickly to X axis endstop and stop there (first pass) G1 H2 U-5 F500 ; go back a few mm G1 H2 U50 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F1000 ; lower Z again G90 ; absolute positioning
That did the trick!
But can you explain why that is? It was H2 in stall detection and I neither understand why it accepts H1 while unhomed nor why it makes a difference triggering the endstop.
I should have asked earlier. I was working on that for about week!
Well since stall detection involves running to the limit of travel I would guess it seemed to be working because the move eventually stopped on it's own when using H2 as opposed to stopping when the stall was detected with H1.
In either case it would happen at the limit of travel so the "homed" position would be the same.
I don't use stall detection so I am guessing here.
