    Duet 2 WiFi/Ethernet Printer Is Not Online
    Duet Web Control
    • michael_t3d
      michael_t3d last edited by
      I own a Modix Big-60 3D printer, and I am trying to run a test print now, but I cannot get the printer to connect to wifi or respond via USB, and no relevant data comes up on the touchscreen panel, it just shows the generic duet screen without anywhere filled in with macros and doesn't show the temp readings either.
      I've been using this guide to try to connect:
      https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s11
      I've taken off the Duet Board from my other printer and it works just fine, so there seems to be some malfunction with this one.
      Troubleshooting:
      1. I've tried all the M commands including the M997 S1 and it has had no effect.
      2. Then I was instructed that when connected via the 24V, the VIN (blue LED), +5V (Red LED) and +3.3V (Green LED) should be lit.
      https://ibb.co/YpssYPD
      Well, in my case VIN doesn't light up:
      https://ibb.co/vqLBN6y
      And I cannot get past this error:
      https://ibb.co/7CbvM63
      (I've also tested if this is related to the cables. I tried several different micro usb cables, some of which are known to work with data, no progress from this effort.)
      Please advise, what the problem is and how I can troubleshoot it.
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @michael_t3d last edited by
        @michael_t3d VIN won't light up if it's not on 12/24v power.
        You could try reflashing the WiFi firmware using M997 S1. The one you want is version 1.23
        michael_t3d 1 Reply Last reply Reply Quote 0
        • michael_t3d
          michael_t3d @jay_s_uk last edited by
          @jay_s_uk said in Duet 2 WiFi/Ethernet Printer Is Not Online:
          Well, it is on 24V power.
          I've tried this command and it didn't help.
          What's the next step?
          • jay_s_uk
            @michael_t3d ah, i was going off the photo you posted showing the USB connection with no 24v cables connected.
            can you post a full output of M122 (copy and pasted rather than an image)
            • michael_t3d
              @jay_s_uk
              Just to double-check, this is the part I need to connect to make sure it's on 24V power, correct?
              • jay_s_uk
                @michael_t3d that looks correct.
                be aware that that board is a pre-production board so the wiring diagram is slightly different https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams#Section_Pre_production_white_Duet_WiFi_boards
                  You can try unplugging the paneldue as well when using just USB power just in case the extra power draw from the panel is causing issues.
                  The results of M122 would be helpful.
                  Can you also provide the results of sending
                  M552
                  M552 S-1
                  M552 S0
                  M552 S1
                  M587
