panelDue version
Hi Guys
Just bought my first duet2 wifi + 5i panel.
I have a lot of issue but I will start with the first
I did update the main board firmware to 3.3, but I have problem with my panel
I see in the upper of the panel in red connecting….i don’t know if it normal
But its seems that my panel not sending command, for example
I can go to "move" to Z+0.5 the touch is OK but nothing happened…..
So I though….lets update panelDue firmware(now its 1.24)..
I tried to do this but got error in DWC "error: m997 aux port 0 ……"
So no firmware update…..
Question:
What is my panel duet version? How can I know?
Or I have other problem?P.S I am connected with 4 pin cable…..
My main board version is v1.04c ( this data was in the main board box….but not for the panel)
Thanks -
@asafo do you have this command in config.g? You need it to enable PanelDue in recent firmware versions:
M575 P1 B57600
PanelDue firmware 1.24 can only be upgraded through the PanelDue USB port, using Bossa on a PC. Once you have upgraded it to PanelDueFirmware 3.3 then you will be able to do future upgrades via the Duet.
@dc42 Thanks a lot I will try.
Thanks for the quick respond -
@dc42 said in panelDue version:
M575 P1 B57600
Thanks
Display issue+firmware is OK.
Open problems:
Fans doesn’t work (0 – part , 1 – heatsink thermostatic I think…E3D V6 volcano part)
Bed heating failed (too slow warm)I will start debug….
At least 2 is behind me:
Firmware
Homing seq – Y endstop is in the Ymax -
To be able to help further we'll need to see your config.g and homing files so we can see how things are currently configured. The results of sending M122 and M98 P"config.g" can be helpful as well.
