Ender 5 Plus with Duet 3 mini 5+ Config
Hello, I have recently installed a Duet 3 Mini into my Ender 5 Plus. I am currently having an issue with homing z and both z motors being synced? It is almost like the steps per mm are off on my z axis motors and it is causing a binding issue when moving the bed up. I also cannot get the bed to lift after the hot end moves to the center to probe. The Bltouch self tests fine, probe deploys and all. Just this issue with the bed.
Here is my known good working very well ender 5 plus configs for you to pick over and see if something jumps out. I have converted to Direct Drive with a .9 stepper on the bondtec extruder and I have tweaked my endstops to give me a bit more bed space. Just to be aware.
bed.g
config.g
homeall.g
homex.g
homey.g
homez.gHope this helps you find your gremlins.
@thebiologist Shouldn't
M92 X160.00 Y160.00 Z8000.00 E873.08
That be Z1600 for 32 microstepping? Not sure I always just use 16 and interpolation.
