Connecting to DWC v3.3.0 via wifi
Duet Web Control
472
  • undefined
    michaelr123
    Hello there,
    So in my adventures to update to latest firmware, I've got my system back up and running after reconfiguring everything. My last struggle is with sketchy wifi signal from my SBC (Pi 3) to my wifi network. I used to be able to leave my computer connected to both ethernet and wifi and just make sure my desktop was on the wifi to connect DWC, but now I've found that if ethernet is on at all I am unable to stay connected to DWC. If I disable my ethernet connection I can then connect to DWC. I'd really like to be able to stay connected to ethernet for gaming while my printer is running, but I want to be able to upload gcode files from this workstation as well.
    Has anyone else run into a similar situation with v3.3.0?
    Thanks,
    -Michael
    • undefined
      That seems more like a router thing than a RRF 3.3 thing. What firmware version were you running before? Have you tried going back to see if the behaviour with the ethernet goes away?
      undefined 1 Reply Last reply 17 Sept 2021, 00:27 Reply Quote 0
      • undefined
        michaelr123 @Phaedrux
        @phaedrux
        I think I was on 3.1-ish?
        In general the board is now just super sketchy, often times on start up the fans never start up, and it says "failed to enable endstops." I'm leaving the pi connected to a screen to help troubleshoot, but I'm often times restarting / power cycling the system a few times before it finally boots properly.
        If all of that goes well, and I home the build, this is usually where it disconnects. I've checked my router, and the pi is actually not connected to the router anymore.
        Any ideas?
        • undefined
          Try a USB wifi dongle with an external antena on the pi?
          Can you post the results of M122?
          You can try enabling some additional monitoring on the Pi to see if its anything duet related that is happening
          https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
          undefined 1 Reply Last reply 17 Sept 2021, 16:36 Reply Quote 0
          • undefined
            @phaedrux
            Thanks, I'll try this later today. Its odd because this exact set of hardware worked great before I messed up and reset everything (reflashed raspbian - duet version, and rrf 3.3.0 manually onto the duet 3 board).
            Would going to a raspberry Pi 4 help at all?
            undefined undefined 2 Replies Last reply 17 Sept 2021, 23:24 Reply Quote 0
            • undefined
              michaelr123 @michaelr123
              @michaelr123 M122
              RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
              Board ID: 08DJM-956BA-NA3TN-6JKF0-3S86T-1VBLS
              Used output buffers: 1 of 40 (10 max)
              Static ram: 150904
              Dynamic ram: 61460 of which 0 recycled
              Never used RAM 141828, free system stack 219 words
              Tasks: SBC(ready,6.5%,318) HEAT(delaying,0.0%,345) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.0%,93) MAIN(running,86.2%,1250) IDLE(ready,0.2%,29), total 100.0%
              Owned mutexes: HTTP(MAIN)
              Last reset 00:00:50 ago, cause: power up
              Last software reset at 2021-09-16 20:20, reason: User, none spinning, available RAM 143092, slot 0
              Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
              Error status: 0x00
              Step timer max interval 128
              MCU temperature: min 16.6, current 26.9, max 27.0
              Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.0, current 12.0, max 12.0, under voltage events: 0
              Driver 0: position 0, standstill, reads 20201, writes 14 timeouts 0, SG min/max 0/0
              Driver 1: position 0, standstill, reads 20201, writes 14 timeouts 0, SG min/max 0/0
              Driver 2: position 0, standstill, reads 20201, writes 14 timeouts 0, SG min/max 0/0
              Driver 3: position 0, standstill, reads 20201, writes 14 timeouts 0, SG min/max 0/0
              Driver 4: position 0, standstill, reads 20204, writes 11 timeouts 0, SG min/max 0/0
              Driver 5: position 0, standstill, reads 20204, writes 11 timeouts 0, SG min/max 0/0
              Date/time: 2021-09-17 18:24:18
              Slowest loop: 0.45ms; fastest: 0.05ms
              === Storage ===
              Free file entries: 10
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === CAN ===
              Messages queued 358, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 253/0/0
              Tx timeouts 0,0,252,0,0,104 last cancelled message type 4514 dest 127
              === SBC interface ===
              State: 4, failed transfers: 1, checksum errors: 0
              Last transfer: 1ms ago
              RX/TX seq numbers: 678/678
              SPI underruns 0, overruns 0
              Disconnects: 1, timeouts: 1, IAP RAM available 0x2c83c
              Buffer RX/TX: 0/0-0
              === Duet Control Server ===
              Duet Control Server v3.3.0
              Code buffer space: 4096
              Configured SPI speed: 8000000Hz
              Full transfers per second: 0.01, max wait times: 9.2ms/0.0ms
              Codes per second: 0.00
              Maximum length of RX/TX data transfers: 2852/84
              • undefined
                ShaunCro
                Sounds like an IP address conflict, try assigning you nic a static IP in the upper part of the IP range.
                Lets just get one thing straight....
                You don't own a Delta! It's true, you don't!
                It owns you!
                undefined 1 Reply Last reply 17 Sept 2021, 23:44 Reply Quote 0
                • undefined
                  michaelr123 @ShaunCro
                  @shauncro It started up just fine this time BTW
                  • I just made the IP address for the printer static, we'll see if that helps?
                  undefined 2 Replies Last reply 18 Sept 2021, 01:11 Reply Quote 0
                  • undefined
                    This post is deleted!
                    • undefined
                      @michaelr123 - Update: ran a job and it went great, still connected to ethernet through desktop and everything's running great!
                      undefined 1 Reply Last reply 18 Sept 2021, 12:48 Reply Quote 0
                      • undefined
                        @michaelr123
                        Interesting note, with the static IP I have a good connection, but sometimes I need to emergency stop the system before everything will fire up. Its not to much of a big deal, any thoughts on why I need to do this?
                        • undefined
                          Phaedrux Moderator @michaelr123
                          @michaelr123 said in Connecting to DWC v3.3.0 via wifi:
                          Should be ok on a pi3, but the pi4 definitely has a lot more breathing room. It might be a useful way to see if it's a hardware problem with
                          the Pi itself, which does occasionally happen.
                          1 out of 12
