    duet3 tool board
    • Mobietec
      Mobietec last edited by
      hi all i need some help i have got the tool board and duet3 im trying to wirer up the two toegther but have come across a problem
      the wiring diag on the duet 3 and tool board do not agree with each other
      ir socket on duet says
      Can 0L
      can 0H
      can 1L
      can 1H
      the tool board just says
      can L
      can H
      can L
      can H
      where do you connect 01 too
      i hope that somone here can in fact help mad dificalt by having two diffrent conector on each end so you cant just pruche a ready made lead
      so i have to make one
      • T3P3Tony
        T3P3Tony administrators @Mobietec last edited by
        @mobietec please see this:
        https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board?revisionid=HEAD#Section_Connecting_WITHOUT_Duet_3_Tool_Distribution_Board
        www.duet3d.com
        Mobietec 2 Replies Last reply Reply Quote 0
        • Mobietec
          Mobietec @T3P3Tony last edited by Mobietec
          @t3p3tony so i only need to connect pins 3and 4 on the toolboard i have the latest with the 120 bridge pins shorted and connect them to pins 3 and 4 on the duet3 so their is only realy 2 wirers connected
          • Mobietec
            @t3p3tony @t3p3tony i think i have it connect when i send command M115 B#
            it replys with
            13/09/2021, 16:50:46 M115 B#
            FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-03b3
            my next question is how to inalise it and tell the system to look at toolboad for fans and heater and extruder etc this is a copy of my config at present many tanks
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 09 2021 20:06:02 GMT+0100 (British Summer Time)
            M550 P"Raptor CoreXY" ; set printer name
            M669 K1 ; select CoreXY mode
            M575 P1 S1 B57600
            M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0.1 S1 ; physical drive 0.1 goes forwards
            M569 P0.2 S0 ; physical drive 0.2 goes forwards
            M569 P0.3 S1 ; physical drive 0.3 goes forwards
            M569 P0.4 S0 ; physical drive 0.4 goes forwards
            ;M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
            M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
            ;M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
            ;M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1 ; set maximum instantaneous speed changes
            M92 X80.00 Y80.00 Z400.00 E94.00 ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00
            (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
            M906 X850 Y850 Z850 E850 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            ;M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
            ;M92 X80.00 Y80.00 Z400.00 E100.00:400.00 ; set steps per mm
            ;M566 X900.00 Y900.00 Z60.00 E120.00:60.00 (mm/min)
            ;M203 X6000.00 Y6000.00 Z180.00 E1200.00:180.00 ; set maximum speeds (mm/min)
            ;M201 X500.00 Y500.00 Z20.00 E250.00:20.00 ; set accelerations (mm/s^2)
            ;M906 X850 Y850 Z850 E850:850 I30 ; set motor currents (mA) and motor idle factor in per cent
            ;M84 S30 ; Set idle timeout
            ; Dual Z Axis
            M671 X-165:165 Y0:0 S2 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
            M208 X-165:170 Y-165:165 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
            M208 X-165 Y-165 Z0 S1 ; set axis minima
            M208 X165 Y165 Z400 S0 ; set axis maxima
            M574 X1 S1 P"io3.in" ; configure active-low endstop for low end on X via pin !io1.in
            M574 Y1 S1 P"io2.in" ; configure active-low endstop for low end on Y via pin !io2.in
            M574 Z2 S2 ; configure active-low endstop for high end on Z via pin !io1.in
            ;M574 X1 S3 ; configure sensorless endstop for low end on X
            ;M574 Y1 S3 ; configure sensorless endstop for low end on Y
            ;M574 Z2 S2 ; configure Z-probe endstop for high end on Z
            M574 Z1 S2 ; set endstops controlled by probe
            M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
            M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            M558 A10 S0.003 B0 R0.2 ; BLTouch extra settings from Phaedrux
            G31 P500 X-22.6 Y-3.0 Z2.5 ; set Z probe trigger value, offset and trigger height
            M557 X-145:140 Y-150:150 P5 ; define mesh grid
            M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
            M307 H0 R0.612 C635.3 D7.63 S1.00 V24.4 ; disable bang-bang mode for the bed heater and set PWM limit
            M308 S1 P"temp1" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp1
            M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
            M307 H1 R3.322 C149.5 D6.72 S1.00 V24.3 ; disable bang-bang mode for heater and set PWM limit
            M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
            M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
            M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
            M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
            M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
            M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
            M106 P3 S1 H1 T45 ; set fan 3 value. Thermostatic control is turned on
            M950 F4 C"out8" Q500 ; create fan 4 on pin out8 and set its frequency
            M106 P4 S1 H1 T45 ; set fan 4 value. Thermostatic control is turned on
            M950 F5 C"out9" Q500 ; create fan 5 on pin out9 and set its frequency
            M106 P5 S1 H1 T45 ; set fan 5 value. Thermostatic control is turned on
            T0
            ;M501 ; load saved parameters from non-volatile memory
            dc42 Phaedrux 2 Replies Last reply Reply Quote 0
              dc42 administrators @Mobietec last edited by dc42
              @mobietec said in duet3 tool board:
              The # character is meant to represent the CAN address of the tool board. So if you are using the default address 121 for the tool board, send: M115 B121
              Mobietec 1 Reply Last reply Reply Quote 0
              • Mobietec
                Mobietec @dc42 last edited by
                @dc42 if i send that command i do get a reply
                13/09/2021, 16:44:30 M115 B121
                Duet TOOL1LC firmware version 3.3beta2+2 (2021-04-16 13:48:06)
                i am asking what i need to do in the config file so to get everything to point to the tool board im a bit of a noob and a bit lost many thanks
                  Phaedrux Moderator @Mobietec last edited by
                  Your toolboard and main firmware are not the same.
                  You should probably be using 3.3 all around.
                  Upload this zip file as is to the system tab in DWC
                  and then check the installed versions with M115 and M115 B121 again after rebooting to see if it took.
                  If it did, great. If not, upload the zip file again and check again. If it's just the toolboard that isn't updating, send M997 B121 to flash the toolboard.
