Z end stop errors posted during auto bed compensation
  • Hi:
    Cartesian Frame
    Mechanical limit switches
    HomeX works properly
    HomeY works properly
    HomeZ works properly
    HomeAll works properly
    When I run the auto bed compensation, I get error messages popping up that say that
    "the Z probe was not triggered during probing move"
    and the utility fails.
    At each probe point, I see the light on the main board turn on for the Z end stop indicating that it has triggered.
    Is there a way to see the gcode that is executing during the auto bed compensation run?
    I don't understand why it is failing, or not registering the z end stop triggering except to observe that the z end stop light goes out between probe points which I think it should (and which matches the error message), or is the z end stop supposed to be triggered throughout the probing duration and how do I make that happen without editing the auto bed compensation code?
    Thanks
    Tim
  • If you have recently updated, make sure deploy and retract probe folders have been deleted.
    Then post your config and bed files.
  • Hi:
    Deploy and retract have been deleted.
    Bed
    [c]
    ; bed.g
    ; generated by RepRapFirmware Configuration Tool on Fri Sep 08 2017 10:03:01 GMT-0400 (Eastern Daylight Time)
    ; Clear any bed transform
    M561
    ; Home all axes
    G28
    ; Probe the bed at 5 points
    G30 P0 X25 Y25 H0 Z-99999
    G30 P1 X25 Y175 H0 Z-99999
    G30 P2 X200 Y175 H0 Z-99999
    G30 P3 X200 Y25 H0 Z-99999
    G30 P4 X140 Y100 H0 Z-99999 S
    [/c]
    Config
    [c]
    ; Configuration file for Duet WiFi (firmware version 1.17)
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M208 X210 Y280 Z180 S0 ; Set axis maxima
    M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
    M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
    G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
    M557 X25:175 Y25:175 S20 ; Define mesh grid
    M569 P0 S0 ; Drive 0 goes backwards
    M350 X128 Y128 Z128 E16 I0 ; Configure microstepping without interpolation
    M92 X640 Y640 Z3200 E100 ; Set steps per mm
    M203 X12000 Y12000 Z1200 E3000 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z100 E5000 ; Set accelerations (mm/s^2)
    M906 X855 Y855 Z855 E855 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M143 S260 ; Set maximum heater temperature to 260C
    M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4725 C0 R4700 ; Set thermistor + ADC parameters for heater 1
    M563 P1 D0 H1 ; Define tool 1
    G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
    G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
    M550 PTevo Tarantula ; Set machine name
    M552 S1 ; Enable network
    ; Access point is configured manually via M587 by the user
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    T1 ; Select first tool
    [/c]
    I think I am going to have to learn a lot more about G-Code
    Thanks
    Tim
  • What are you using for a probe? You don't have anything in your M558 for it.
  • Well. that might be causing my issue. I don't have a probe. I had an SN04 from my Tevo Tarantula, but I didn't want to modify the Duet to use it on this board. I have ordered one of DC42s probes, but I don't have it yet. All I have is the Z limit switch which I had hoped would allow me to print while I was waiting for the probe to arrive.
    I haven't managed to get my first print done yet.
    Can I just comment out the M558 for now? Will it then use my z limit switch, or will it just fail?
    Thanks
    Tim
  • Just don't run the bed compensation.
  • Ok, Thanks very much.
    Now I can work setting up the 1st layer and so on.
Locked
