EZABL probe died... can I continue to print?
Hi All - my EZABL probe is faulty and while I working with TH3D on warranty replacement, I wanted to see if there's still a way I can configure the printer to level correctly so I can still print files without some sort of ABL? Is there an article/previous post I can read up on as I need to get some things printed and my other printer is on a 4 day job.
Thanks for any help and insight
You can change to
M558 P0
which will use manual probing. It will prompt you to jog the Z axis down whenever it needs to probe.
