    Activate GP1 output by zprobe.in or endstop X and Y
    Using Duet Controllers
    437
    • krys3dundefined
      krys3d
      hello everyone, i have my 3d printer project going well.
      I am under RRF3 with a duet 2 wifi + duex5 and I would like to use a GPIO output to activate an LED indicator when detecting an endstop X, Y or zprobe.in sensor
      For the wiring, no problem, but for the configuration I'm struggling.
      I declared the GP1 output as follows:
      M950 P0 C "duex.gp1"
      But then I block
      I am thinking of using M581 P "xstop+ystop+zprobe.in" T "duex.gp1" S1 R0
      but it does not work.
      Do you have any advice to give me.
      Thank you, and have a good day
      jay_s_ukundefined OwenDundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @krys3d
        @krys3d use daemon.g
        something like
        if {{sensors.endstops[0].triggered || sensors.endstops[0].triggered = true} || sensors.probes[0].value[0] > 500}
           M42 P0 S1
        else
           M42 P0 S0
        that turns on the output if X, Y or the probe are triggered
        • OwenDundefined
          OwenD @krys3d
          @krys3d said in Activate GP1 output by zprobe.in or endstop X and Y:
          But then I block
          Assuming you're running latest firmware
          It's untested but it may be possible
          Try this in config.g to create triggers for both rising and falling conditions if that's possible
          M581 T3 X Y Z S1
          M581 T4 X Y Z S0
          Then create a file trigger3.g
          Inside that use M42 to control your gpio pin
          M42 P0 S1
          create file trigger4.g
          M42 P0 S1
          krys3dundefined 1 Reply Last reply Reply Quote 1
          • krys3dundefined
            krys3d @OwenD
            @owend
            Thank you very much,
            there is a lot of progress with this:
            M581 T3 X Y Z S1
            M581 T4 X Y Z S0
            trigger3.g
            M42 P0 S0
            trigger4.g
            M42 P0 S1
            The led activates well when the X or Y sensors are activated, but for the Z it does not work, there must be a small modification to make
            My Z sensor is configured as follows:
            M574 Z0 P "nil"
            M558 P5 C "zprobe.in" H50 F120 T10000 A5 S0.01
            My firmware configuration is as follows:
            Circuit: Duet 2 WiFi (2WiFi)
            Firmware: RepRapFirmware for Duet 2 WiFi / Ethernet 3.2 (2021-01-05)
            Duet WiFi Server Version: 1.23
            I tried to replace in the M581 the Z by
            "zprobe.in"
            but it has no effect
            OwenDundefined 1 Reply Last reply Reply Quote 0
            • OwenDundefined
              OwenD @krys3d
              @krys3d
              Try
              M581 T3 X Y P"zprobe.in" S1
              M581 T4 X Y P"zprobe.in" S0
              I think the axis letters may only work on end stop pins, so you need the P parameter for the probe.
              Again untried, just spitballing
              • krys3dundefined
                krys3d
                @owend
                unfortunately, I tried with / without P but nothing worked, the signal is not interpreted unlike the X or Y sensor.
                In fact I just wanted the led for the Z sensor (zprobe.in), the other X and Y sensors were used to verify that the operation was possible, and I know that it is doable.
                On the other hand I still do not understand why the signal of "zprobe.in" is not interpreted
                Thank you very much for your help.
                I am also looking on my side, but there is little information on the use that I want to make.
                Maybe I could duplicate the signal from my Zprobe sensor by plugging the signal output into a GPIO input in addition to the zprobe.in?
                • krys3dundefined
                  krys3d @OwenD
                  @owend
                  I managed to use double the signal from zprobe.in on input GP1 and assigned the output to GP2 as follows :
                  ; Led Capteur Nivellement GPIO 2
                  M950 J0 C"duex.gp1"              ; Duplication signal Capteur Z GPIO 1
                  M950 P0 C"duex.gp2"              ; Sortie GPIO 2 Allumage Indicateur Led
                  M581 T3 P"duex.gp1" S1           ; Activation fichier trigger3.g
                  M581 T4 P"duex.gp1" S0           ; Activation fichier trigger4.g
                  trigger3.g
                  M42 P0 S0
                  trigger4.g
                  M42 P0 S1
                  it works well, but when starting the card, the output is always active until the first switchover of the contact, is there a command to initialize the output to 0 or force the output to update?
                  • OwenDundefined
                    OwenD @krys3d
                    @krys3d
                    Try M582 immediately after your M581 calls
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M582_Check_external_trigger
                    krys3dundefined 1 Reply Last reply Reply Quote 0
                    • krys3dundefined
                      krys3d @OwenD
                      @owend
                      A very big thank you to you for taking the time to help me. It's really awesome.
                      The M582 is indeed an initialization of the trigger compared to the received signals, it works perfectly
                      Here are my command lines if anyone ever needs them:
                      M950 J0 C"!^duex.gp1"            ; Duplication signal Capteur Z GPIO 1
                      M582 T3                          ; Initialise Trigger 3
                      M582 T4                          ; Initialise Trigger 4
                      Trigger 3 :
                      M42 P0 S1
                      Trigger 4 :
                      M42 P0 S0
                      • krys3dundefined
                        krys3d @krys3d
                        Here is a little test video, for information, I plugged the X's sensor into the Zprobe connector for testing and it works fine.
                        I still have to install the Zprobe sensor as soon as I receive it.
                        https://youtu.be/vkGkOMY7Mt4
                        Good day
