Solved Duet Tool Board v1 fan question
I have a Duet Tool Board v1.1. I'm trying to map 2 outputs to run together for dual layer fans. 1 Layer fan is connected to out1 and the other is connected to out2. There's 2 sliders in DWC and both fans work individually. I expected when I move one slider both fans will spin together.
; ========================= Fans =========================== M950 F0 C"20.out1" Q500 ; create fan 0 on pin out9 and set its frequency M950 F1 C"20.out2" Q500 ; create fan 0 on pin out9 and set its frequency M106 P0 C"Layer Fan1" S0 H-1 ; set fan 0 value. Thermostatic control is turned off M106 P1 C"Layer Fan2" S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F2 C"0.out7"; Q25000 ; create fan 1 on pin out8 and set its frequency M106 P2 C"WC Fan" H1 T40 ; set fan 1 value. Thermostatic control is turned on ; ======================== Tools =========================== M563 P0 D0 H1 F0:1 ; define tool 0
@dhusolo said in Duet Tool Board v1 fan question:
No, there will be sliders for each fan individually. To control both of the fans assigned to the tool, use the tool fan slider in DWC which will control the fan(s) of the currently selected tool.
@phaedrux Haha genius. I missed that one. Thanks
