SD card reader module
Good morning,
I have tried to connect a SD card reader module in duet Duet 3 Mainboard 6HC connecting it to SBC 26 Pin Header and I have not been able to get it to work, in duet 2 wifi I connect it to PanelDue (Label: CONN_SD) and it works.
On Duet 3 Mainboard 6HC should I connect it here? or should I add some kind of configuration? or is it possible to make this connection?
I don't use SBC
I have the 5v power configuration as it comes by default
Best regards
@aitor Sorry, there is no firmware support for an external SD card on the Duet 3 6HC.
Ok @droftarts , eso explica porque no funciono
Tienen pensado agregarlo en algún momento? o esta totalmente descartado?
Me parecería interesante añadirlo, todavía hay clientes que me dicen que prefieren trabajar así
Un saludo
@aitor said in SD card reader module:
Ok @droftarts, that explains why it didn't work
Do you plan to add it at some point? or is it totally ruled out?
It would be interesting for me to add it, there are still clients who tell me that they prefer to work like this
All the best
@dc42 will need to respond; I don't know if it's even possible.
Add it to the firmware wishlist?Sorry, already is!Ian
