PT100 issues - my fault
I'm getting some PT100 temperature fluctuations with effector movement, so I'm suspecting the wiring on my smart effector. I have also stripped the screw terminals on the RTD board.
Couldn't locate a BOM in KiCAD files on github.
Q1: What is the part number for the Molex KK crimps used on the 8 way SIL connector on the Smart effector - I would like to replace the crimps in the cable harness to gold plated.
Q2: What is the part number for the 4 way screw terminal connector used on the RTD board
Many Thanks,
J.
@jujudelta for the Smart Effector crimp pins, see https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers. The terminal block on the PT100 board is just a standard 4 way 2.54mm pitch one.
Most likely you have a bad crimp connection on one of the PT100 pins in that 8-way connector.
@jujudelta said in PT100 issues - my fault:
I don't think that's supposed to be installed like that - if you have a four-wire connection, the jumpers should be off (or at least, not shorting - I normally turn them 90 degrees and leave them on one pin). Effectively I think you've turned a four-wire PT100 into a 2-wire one.
(Or is that a temporary fix due to your connection problem? )
@achrn Yes I was trying to debug my 2 wire PT100 circuit, hence the doubling up of the wires.
This was the culprit in the end......
Will recrimp at work tomorrow with the proper molex microfit tool.
Luckily I have a spare PT100
