Obtain slicer settings from gcode
I have the gcode file, from a piece that I printed a long time ago...
And now, months later I want to print the symmetrical piece, and I would like a finish as similar as possible.
The problem I find is that I don't remember the settings I use, I think I use Cura.
How can I get that data from the gcode I have?(layer heights, speeds, housings,....) as much data as you can, so that the new piece is not very different from the printed one
Thx
@peirof if you open the GCode file in a text editor, at the start or the end of the file you will probably find a large comment block that lists the settings.
@dc42 thx
