    Custom palette in bmp2c.go file
    Firmware developers
    paneldue bmp2c palette
    • Nil Orbachundefined
      Nil Orbach
      Hi everyone,
      I would like to custom the bmp2c tool in order to make my own palette (like adding some blue for my icons, etc.), so I am looking for information about the color conversion that is performed. In the bmp2c.go file, the function getPaletteIndex() calls the to16BitColor() and performs a switch depending on its result (see below).
      func getPaletteIndex(r, g, b, a uint32) int {
      	// 0x0000, 0xffff, 0x20e4, 0xffdf, 0x18e3, 0xf79e, 0xc986, 0xd30c,
      	// 0xc103, 0xff52, 0xfffb, 0x4569, 0x9492, 0x0000, 0x0000, 0x0000
      	switch to16BitColor(r, g, b, a) {
      	case 0xffff: // e.g. 0xffffff
      		return 1
      	case 0x20e4: // e.g. 0x201c20
      		return 2
      	case 0xffdf: // e.g. 0xf8f8f8
      		return 3
      	case 0x18e3: // e.g. 0x181c18
      		return 4
      	case 0xf79e: // e.g. 0xf0f0f0
      		return 5
      	case 0xc986: // e.g. 0xc83030
      		return 6
      	case 0xd30c: // e.g. 0xd06060
      		return 7
      	case 0xc103: // e.g. 0xc02018
      		return 8
      	case 0xff52: // e.g. 0xf8e890
      		return 9
      	case 0xfffb: // e.g. 0xf8fcd8
      		return 10
      	case 0x4569: // e.g. 0x40ac48
      		return 11
      	case 0x9492: // e.g. 0x909090
      		return 12
      	default:
      		return 0
      func to16BitColor(r, g, b, a uint32) uint16 {
      	return uint16((r&0xF8)<<8) | uint16((g&0xFC)<<3) | uint16((b&0xF8)>>3)
      As to16BitColor converts r, g, b into a single uint16_t, there sould be a multitude of possible outputs for this switch: 2^16 = 65,536 colors! So, why are there only 13 outputs? I mean, from a 24-bit image.bpm taken as input, how is it possible that all the colors (2^24 !) can match these 13 outputs?
      I have already looked into the image library of golang here which is used in the file (especially the At() and bmp.Decode() functions) but I did not find the answer I was looking for (also, I am not familiar with Go!).
      Is there anyone having worked on the bmp2c.go file who could help me? 🙂
      • mfs12undefined
        mfs12
        Moved to the developers forum.
        Visit me on github at https://github.com/mfs12/
