Accurate print time stimation without DWC
Very often I use the option to simulate the gcode that I am going to print with DWC. The drawback I see is that when I'm printing, I can't simulate it, to get an idea of the time it will take, with the Slicer options selected.
The time estimate given by the slicer I use doesn't help either, 90% of the cases Cura.
So:
- Is there any way to simulate printing with MY PRINTER, as I have it configured? (without using the printer itself, since it will possibly be printing)
- Is there a slicer (even if I only use it for time estimation) that gives a reliable calculation of the printing time?
Thanks
This website does a very good job at estimating the print times. You just have to plug in the info about your machine.
@bot thanks
I suppose its Duet friendly?
Yes, it's very good for duet. Although, it does not take into account pressure advance, and any slowdowns that could be incurred because of it.
