Calibration of Titan Extruder.
Good day!
I'm newbie. Found the command M564 H0 on the forum. Does not help. How to enable material extrusion on cold? I want to calibrate my extruder correctly, set the desired motor step. Thanks. -
@romanvin M302 P1
@jay_s_uk It worked. Thanks. But why in the command description?
@romanvin m564 is about moving outside of the axis limits.
Descriptions of each gcode can be found here duet3d.dozuki.com/Wiki/Gcode -
@jay_s_uk Thank you very much. Now there is an enlightenment in the head.
Live for 100 years and study for 100 years - There is a proverb.
