    DWC Custom Configuration
    Duet Web Control
    13
    42
    3.5k
    • theKMundefined
      theKM @oozeBot
      @oozebot ...three line change to have it stay put all the time; in App.vue, remove "hidden-md-and-up" from the button, and "|| $vuetify.breakpoint.mdAndUp" from the panel container and divider.
      • theKMundefined
        theKM
        Messing with menu config after work...
        • config comes from and stored in 'dwc-settings.json' along with everything else
        • default works as-is, nobody will know anything is different until they tweak the config of it themselves
        • complete control over the menu; change the order of it, flatten it (remove the groupings), add buttons that run gcode including adding them to submenus, create submenus, change the icons and colours (yup, can have a menu of macros that run directly from the menu, because why not!? )
        • internally the system pages are tweaked how they register in to the menu, but no-change for existing plugins to be able to plonk them somewhere specific by configuration.
        Good fun. 🙂
        • chimaeraghundefined chimaeragh referenced this topic
