    [3.4.0b4] Expression nesting too deep
    Beta Firmware
    • gloomyandyundefined
      gloomyandy
      When running with 3.4.0b4 in SBC mode using a macro that contains the following:
          if abs(move.calibration.initial.deviation - move.calibration.final.deviation) < 0.0005
              echo "Calibration complete"
              break
      Produces the following error:
      Error: Failed to read code from macro test macro: Failed to evaluate "abs(move.calibration.initial.deviation - move.calibration.final.deviation) < 0.0005": Expression nesting too deep
      Originally detected with the STM32F4 port but confirmed with a Duet setup by @jay_s_uk
      On the STM32F4 I tracked this down to a stack check exception being thrown in ObjectExplorationContext::CheckStack. If I increase the SBC/Linux stack size to 1000 words (arbitrary size chosen!), then the code works, but this may not be the best solution.
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @gloomyandy
        Confirmed on a duet 3 mini + SBC running 3.4b4
        • chrishammundefined
          chrishamm administrators @jay_s_uk
          @gloomyandy @jay_s_uk Thanks, I'll have a look.
          Duet software engineer
            dc42 administrators @gloomyandy
            @gloomyandy thanks for reporting this. I have reduce the stack usage of ExpressionParser::ParseIdentifierExpression, which had grown in beta4, and increased the SBC task stack size from 820 to 1000 words.
