    InputShaping-Plugin-0.2.0-pre5 released
    Plugins for DWC and DSF
    891
    • Heartleander81undefined
      Heartleander81
      Hi. I have the plugin running.
      I had start-up problems because I had forgotten to update my toolboard to firmware 3.4b4.
      I now get data that I have to deal with now.
      Thanks for the work you put in there.
      • xiaokundefined
        xiaok @mfs12
        @mfs12
        Hello, I submitted a PR from github to support Simplified Chinese, you can take a look, if you have any questions, please let me know.
        thanks
        mfs12undefined 1 Reply Last reply Reply Quote 0
        • mfs12undefined
          mfs12 @xiaok
          @xiaok, this is very nice, thank you. I will get back to as soon as the plugin gets more production ready and the texts finalized.
          Visit me on github at https://github.com/mfs12/
          • mfs12undefined
            mfs12
            @xiaok i didn't receive an PR.
            xiaokundefined 1 Reply Last reply Reply Quote 0
            • xiaokundefined
              xiaok @mfs12
              @mfs12 Good morning, branch at inputshaping-accel-plugin
              https://github.com/mfs12/DuetWebControl/pull/18
              kluoyun opened this pull request in mfs12/DuetWebControl
              open Inputshaping accel plugin #18
              • SilviuZundefined
                SilviuZ @mfs12
                @mfs12 hi!
                I've tested the plugin and its working nice.
                can I suggest to have a automatic ringing test going trough the range 15-150 HZ with the option of changing in between NONE, ZVD, ZVDD EI2, EI3, minimum acceleration and the damping factor.
                Thank you
                • mfs12undefined
                  mfs12
                  @SilviuZ, can you be more specific about the ringing test. what do you exactly mean by that?
                  SilviuZundefined 1 Reply Last reply Reply Quote 0
                  • SilviuZundefined
                    SilviuZ @mfs12
                    something that can generate multiple auto tuning algorithms similar with below to find the perfect input shaping values in type, hz and damping values
                    0-ei3-dba218c3 1633266073427 1000 1356 0 ei3 25 0.1 800
                    1-ei3-dba218c3 1633266078416 1000 1356 0 ei3 26 0.1 800
                    2-ei3-dba218c3 1633266083309 1000 1353 0 ei3 27 0.1 800
                    3-ei3-dba218c3 1633266088439 1000 1361 0 ei3 28 0.1 800
                    4-ei3-dba218c3 1633266093576 1000 1357 0 ei3 29 0.1 800
                    5-ei3-dba218c3 1633266098567 1000 1356 0 ei3 30 0.1 800
                    6-ei3-dba218c3 1633266103563 1000 1366 0 ei3 31 0.1 800
                    7-ei3-dba218c3 1633266108571 1000 1356 0 ei3 32 0.1 800
                    8-ei3-dba218c3 1633266113494 1000 1356 0 ei3 33 0.1 800
                    9-ei3-dba218c3 1633266118404 1000 1359 0 ei3 34 0.1 800
                    10-ei3-dba218c3 1633266123400 1000 1363 0 ei3 35 0.1 800
                    11-ei3-dba218c3 1633266128449 1000 1356 0 ei3 36 0.1 800
                    12-ei3-dba218c3 1633266133376 1000 1356 0 ei3 37 0.1 800
                    13-ei3-dba218c3 1633266138590 1000 1363 0 ei3 38 0.1 800
                    14-ei3-dba218c3 1633266143640 1000 1359 0 ei3 39 0.1 800
                    15-ei3-dba218c3 1633266148722 1000 1353 0 ei3 40 0.1 800
                    • mfs12undefined
                      mfs12
                      @SilviuZ, a feature like this will come very likely.
                      • mfs12undefined
                        mfs12
                        New release was published. Check...
                        https://forum.duet3d.com/topic/25515/inputshaping-plugin-0-2-0-pre6-released/1
