    2 issues from Pausing print - sets new base speed bug
    Beta Firmware
    • jbergeneundefined
      jbergene
      Ok i was printing a thin piece of sheet at
      first layer 60mms.
      once I saw good adhesion i increased 300% to 180mms
      PRinter is configured to run at maxium 400mm/s (24000mm/min)
      However, once I Resumed the print, it used the previous 180mms as 100% and now ran the printer at 540mms.
      So there are 2 bugs. First is that it used the old speed values to set new 100% value, and second is that it printed above the hard-coded configured speed.
      I Tried to revert it by setting the speed to 33% -> Pause -> resume -> speed 100%
      it now ran 60mms again as base speed.
      Version 3.4.0 B3
      • T3P3Tonyundefined
        T3P3Tony administrators @jbergene
        @jbergene please could you check if this is still an issue with RRF 3.4b4. Also is this running in stand alone or SBC mode?
        www.duet3d.com
        • jbjhjmundefined
          jbjhjm
          Experienced this too when I tweaked speed multiplier strongly during a very difficult layer:
          Set to 20%, paused, resumed.
          Multiplier still displays at 20%, but actual speed seems to be 20% * 20%.
          Setting the multiplier to 50% will set the actual speed to 50% * 20%.
          Some time later, the real speed will jump to 50%.
          Could not determine WHEN this happens exactly.
          Using 3.4.0 b3 with 6HC, SBC and Toolboard 1.1.
          Could not test at 3.4.0 b4 cause there is a known bug of aborted prints when pausing/resuming in SBC configuration.
          • T3P3Tonyundefined
            T3P3Tony administrators @jbjhjm
            @jbjhjm said in 2 issues from Pausing print - sets new base speed bug:
            this is fixed in 3.4b5 can you see if the pause speed bug is fixed as well please
            www.duet3d.com
            jbjhjmundefined 1 Reply Last reply Reply Quote 0
            • jbjhjmundefined
              jbjhjm @T3P3Tony
              @t3p3tony just upgraded, will check this later today!
              • jbjhjmundefined
                jbjhjm
                Pausing works fine again and the speed multiplier seems to be fixed too!
                T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
                • T3P3Tonyundefined
                  @jbjhjm thanks for the update!
                  www.duet3d.com
