    Solved Duet 3 mini+ red/green led keeps flashing card unresponsive
    • Alucardi
      Alucardi last edited by Alucardi
      I came down and saw that my bl touch was flashing and printer just stopped mid print. Now i cannot get it to connect to wifi. Red and green keep blinking but stops for a few seconds and the red led by it self blink a few times then they are back to flashing. What could have happend? Running it on USB red and green are solid and i can connect through wifi.
      • Alucardi
        not much help here but i figured out it was the powersuply.
          dc42 administrators @Alucardi last edited by dc42
          @alucardi I'm glad you sorted it out.
          If you get flashing LEDs again, please tell us which LEDs are flashing. There are two red and two or three green ones. I guess in this case it was the red +5V and green +3.3V ones that were flashing, not the red Status LED which flashes during normal operation.
          One of our support staff is currently not working, so response to forum questions is slower than usual.
          Alucardi 1 Reply Last reply Reply Quote 1
          • Alucardi
            Alucardi @dc42 last edited by
            @dc42 said in Duet 3 mini+ red/green led keeps flashing card unresponsive:
            Eventually i found this link https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond After using that one i figured out that it must be the power supply. It was a bit hard to find, had to use google.
