    Expansion tool board immediate heater fault (Duet 3)
    • Ben_Pauza
      Ben_Pauza last edited by
      I have a 1.1 toolboard and am powering a fan and hotend. I am running my hotend thermocouple back to the main board where I have a thermocouple daughterboard.
      This setup creates an immediate fault of my hotend. I don't get an error code. The heater status just goes from active to fault and I have to reset it. I read:
      "A heater on an expansion or tool board can only be controlled by a temperature sensor on the same expansion board. This is a safety precaution."
      Does this mean my configuration is not going to work? I'd really like to use a thermocouple instead of using one of the other ports on the motherboard. I guess I could run heater wires back to the main board but that's kind of taking away from the purpose of having a toolboard in the first place.
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @Ben_Pauza last edited by
        @ben_pauza said in Expansion tool board immediate heater fault (Duet 3):
        You've quoted the relevant part, that the temp sensor must be connected to the expansion board where the heater is connected.
        So clearly trying to use a sensor, in this case your thermocouple, connected to the main board violates that rule.
        Are the alternative temp sensors that can connect to the expansion board unsatisfactory in your application?
        Ben_Pauza 1 Reply Last reply Reply Quote 0
        • Ben_Pauza
          Ben_Pauza @fcwilt last edited by
          @fcwilt A PT1000 sensor may work. I print at very high temperatures and would like to maintain the performance of a thermocouple though.
          • fcwilt
            To date I've only used thermistors. As part of my ongoing education I just got a few PT1000 units to try.
            I've heard of thermocouples but know little about them.
            Is there any sort of device that can allow using a thermocouple to a connection that supports a PT1000?
            Thanks.
