    Connecting Development Server - SBC Setup
    Duet Web Control
    • BorealisCNC
      BorealisCNC last edited by
      Struggling with something that probably shouldn't be giving me as much trouble.
      I want to connect the development NPM server to my Duet3.
      I did the usual git fun, and made a local branch for DWC, made a simple change (building a laser... I don't have a Z axis! just xy), and then did:
      npm install
      npm run serve
      From there, I can load it in Chrome.
      But clicking the connect button...
      I have tried connecting using both duet3.local, and the IP address I normally use to access Duet Web Control.
      I have a Duet3 running with a raspberry pi 4 in SBC mode.
      version numbers:
      Board: Duet 3 MB6HC (MB6HC)
      DSF Version: 3.3.0
      Firmware: RepRapFirmware for Duet 3 MB6HC 3.3 (2021-06-15)
      Duet Web Control 3.3.0
      Also, when I added "M586 C"*", it reports the following error:
      M552: Network-related commands are not supported when using an attached Single Board Computer
      Are there any additional steps I needed to take? Any steps because I have an SBC installation?
      Thanks in advance!
      • T3P3Tony
        T3P3Tony administrators @BorealisCNC last edited by
        @borealiscnc might be worth starting with the standard install of DSF and DWC to see how it all hangs together.
        www.duet3d.com
        • 3DPandME
          3DPandME last edited by 3DPandME
          Sorry to revive this but I am having the exact same issue. I have a clean copy of DWC. No changes at all and I have a Duet board running in SBC mode. I have tried to enter the ip address i usually use to access this board in the browser but I get this error
          3DPandME 1 Reply Last reply Reply Quote 0
          • 3DPandME
            3DPandME @3DPandME last edited by
            @3dpandme when i enter that IP address in my browser it connects fine so I'm a bit confused by the network error.
