    Solved Homing reset before complete
    • pajacyk0v
      pajacyk0v last edited by pajacyk0v
      I installed new 6HC with latest stable RF 3.3 on my printer. Form the begining I have problem with homing procedure. When printer is powered on first homing allways act as following:
      • carriage going fast to X endstop
      • stops on endstop
      • move backward
      • going slow to X endstop
      • stops on endstop
      • carriage going fast to Y endstop
      • stops just before endstop (!!!)
      • run G28 again (!!!) with succeed
      • throws Error: G0/G1: insufficient axes homed
      It only happens when printer lost coordinates. If homing suceed once, all another attempts also succeed
      All endstops are optical (NO) form TriangleLabs. Printer with CoreXY kinematics.
      homeall.g
      G1 H2 Z8 F600          ; lift Z relative to current position
      G1 H1 X-235 F4800 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F4800       ; go back a few mm
      G1 H1 X-235 F600  ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-275 F4800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F4800       ; go back a few mm
      G1 H1 Y-275 F600  ; move slowly to Y axis endstop once more (second pass)
      G1 X107 Y127 F4800         ; go to first bed probe point and home Z
      G30                     ; home Z by probing the bed
      kinematics settings are following (config.g)
      M669 K1                                               ; select CoreXY mode
      M569 P0.0 S0 D2
      M569 P0.1 S0 D2
      M584 X0.0 Y0.1 Z0.2 E0.3                              ; set drive mapping
      M350 X16 Y16 Z8 E64 I1                             ; configure microstepping without interpolation
      M208 X0 Y-22 Z0 S1					    ; set axis minima
      M208 X215 Y255 Z440 S0                                ; set axis maxima
      M574 X1 S1 P"io1.in"                                  ; configure active-high endstop for low end on X via pin io1.in NO
      M574 Y1 S1 P"io2.in"                                  ; configure active-high endstop for low end on Y via pin io2.in NO
      • T3P3Tony
        T3P3Tony administrators @pajacyk0v last edited by
        @pajacyk0v said in Homing reset before complete:
        its possibly not moving far enough?
        Your Y axis length is specified as 277mm (-22 to +255) but your homing file only moves 275mm
        Try changing this line in your homing file
        from this:
        to this:
        G1 H1 Y-300 F4800 ; move quickly to Y axis endstop and stop there (first pass)
        www.duet3d.com
        pajacyk0v 2 Replies Last reply Reply Quote 1
        • pajacyk0v
          pajacyk0v @T3P3Tony last edited by
          @t3p3tony OMG! I looked into gcode soo long and I didn't notice that bed toolbar have negative values XD
          • pajacyk0v
            @t3p3tony you were rigtht. I'm an idiot 🙂
            We can close this topic.
