    Issues defining a new command.
    Firmware developers
    • jazbaatbadalgaye
      jazbaatbadalgaye last edited by jazbaatbadalgaye
      I am trying to write a new M810 command to display an array. Here is what I did
      1. Declared a function which returns a pointer to an array.
      //In reprap.h
      uint8_t *Gen() noexcept;
      uint8_t* my_pointer = Gen();
      1. Definition of the function
      //in reprap.cpp
      uint8_t *RepRap::Gen() noexcept
      	uint8_t arr[3]={5};
      	return arr;
      1. Declared the new Gcode function
      //in GCodes.h
      void GetData(const StringRef& reply) noexcept;
      1. Definition of the new Gcode
      //in GCodes.cpp
      void GCodes::GetData(const StringRef& reply) noexcept
           for (size_t c=0; c<3;c++)
      		reply.catf("Arr:  %u" PRIu8 "\n", reprap.my_pointer[c]);
      1. Added M810
      //in GCodes2.cpp
      case 810:
          GetData(reply);
          break;
      But when I send M810 on YAT, I get gibberish values like
      Arr:  0hhu<LF>Arr:  0hhu<LF>Arr:  2hhu<LF>
      What am I doing wrong?
      Edit : Fixed it by declaring the
      uint8_t arr[3]={5};
      as
      static uint8_t arr
      • oliof
        oliof last edited by
        I think you're not dereferencing your pointer correctly?
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
          @jazbaatbadalgaye function Gen returns a pointer to data in local storage that ceases to exist when the function returns.
          jazbaatbadalgaye zapta 2 Replies Last reply Reply Quote 0
          • jazbaatbadalgaye
            jazbaatbadalgaye @dc42 last edited by
            @dc42 Thanks! I fixed it by declaring the arr as static
            • zapta
              zapta @dc42 last edited by
              @dc42 said in Issues defining a new command.:
              Some compiler flag this out
              https://docs.microsoft.com/en-us/cpp/error-messages/compiler-warnings/compiler-warning-level-1-c4172?view=msvc-160
