    Part Cooling fan Wont turn off - Fan0
    • Adamfilip
      Adamfilip last edited by
      Fan0 on my Duet Wifi wont turn off even if the value is set to 0
      is a 2 wire blower fan
      M950 F0 C"fan0" Q500 ;create fan 0 on pin fan0 and set its frequency
      cosmowave T3P3Tony 2 Replies Last reply Reply Quote 0
      • cosmowave
        cosmowave @Adamfilip last edited by
        @adamfilip which FW are you using?
        Is the wiring correct?
        Can you control the speed or is the fan always on full speed?
        Mankati FSXT+, DeltaTowerV2, CBot3D
        Adamfilip 1 Reply Last reply Reply Quote 0
        • T3P3Tony
          T3P3Tony administrators @Adamfilip last edited by
          @adamfilip sounds like a fan MOSFET may have blown. What happens if you swap to fan 1 or fan 2 if fan 1 is in use
          www.duet3d.com
          • Adamfilip
            Adamfilip @T3P3Tony last edited by
            @t3p3tony if I use Fan2,, its the same.
            and speed can be controlled just not to none
            • Adamfilip
              Adamfilip @cosmowave last edited by
              @cosmowave
              I can control speed but not turn it off
              Board: Duet 2 WiFi (2WiFi)
              Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
              Duet WiFi Server Version: 1.25
              T3P3Tony cosmowave 2 Replies Last reply Reply Quote 0
              • T3P3Tony
                @adamfilip ahh ok not the same issue. please post the model number of the fan and a clear pic of how it is wired. Also is this a new fan or did it used to work before?
                www.duet3d.com
                • cosmowave
                  @adamfilip can it be that something is wrong in the wiring of the fan?Perhaps a defect fan-cable which has a little conductivity to GND?
