Config for the Pinda v2 ,need help!
@lui2004 there is not the option of using a table like i think Marlin has. You configure the S and C parameters within G31 to compensate:
https://duet3d.dozuki.com/Wiki/G31Based on this thread:
https://forum.duet3d.com/topic/16972/pinda-2-probe-with-temperature-compensation/5?_=1593546022132It appears the non linearity of the measurements at different temperatures could be a problem.
The poster in that post shows a conditional gcode way to get around the problem. Before you do that it would be worth testing you can get a good z probe performance with everything (including the PINDA temperature) at a steady temperature.
Once thats working then non linear temperature compensation can be looked at,
Thanks ,i will give it a try!
Other question when print is finished my z axis at 0 what i can do that the z-axis goes u after print?
@lui2004 in the end gcode you can add a move to lift slightly and move the tool out the way.
E,g,
G91 ; set to relative positioning G1 Z5 ; raise Z 5 mm G90 ; set to absolute positioning G1 X0 Y0 ; park at X0 Y0
