    Which Duet has the fastest external drivers
    • Marius Breuer
      Marius Breuer last edited by
      I'm comparing the different Duet boards for use in my upcoming 3d printer. So far I've only used the Duet 2, but would be willing to upgrade to Duet 3 (6HC or Mini).
      As I will be using external stepper motor drivers, I'm only concerned with the maximum step frequency for those.
      afaik the Duet 3 6HC is the fastest, but offers no connections for external drivers, same with the Duet 3 Mini.
      Connecting the 1XD Expansion Board limits the step frequency to the 48 MHz chip, so around 50KHz according to the wiki.
      Seems like I'm left with the Duet 2 and it's Expansion Breakout Board, although I've not seen any benchmarks for the expansion board.
      Am I missing something?
      Which would be the best performing Duet for a 3d printer (X,Y,Z,E axis) with four external drivers?
      Why is there a 1XD Expansion Board with such a low performance chip, compared to the 6HC? People, that would spend money on a 6HC, external drivers (stepper or servo in my case) surely would take a 10-20€ more expensive 1XD, if it means 5-10x the step rate.
      While I'm at it: how about a 3XD to fully utilize faster chips. I'd guess there are many people, that wouldn't need just one external drive in their setup, so a 3XD could offer greater performance with the chips cost increase "spread across" mutiple axis.
      Thanks!
      Sources:
      Benchmarks from another topic
      https://forum.duet3d.com/topic/15308/what-is-the-maximum-step-rate-of-duet-3-board/8
      1XD benchmarks from wiki
      https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_1XD
      T3P3Tony dc42 2 Replies Last reply Reply Quote 0
      • T3P3Tony
        T3P3Tony administrators @Marius Breuer last edited by
        @marius-breuer
        Currently if you need external drivers then in some cases the Duet 2 is faster and in other the 1XDS would be faster. For example if you need to run a kinematics where a lot of calculations are required then the Duet 3 with 1XDs may be faster than the Duet 2. Alternatively if you are just going fast on a cartesian XY stage then the Duet 2 may be faster.
        often a limiting factor is the step timing requirements of the external drivers.
        We will bring out a 6XD however development is taking time due to other priorities.
        www.duet3d.com
        Marius Breuer 1 Reply Last reply Reply Quote 1
          dc42 administrators @Marius Breuer last edited by
          @marius-breuer the maximum step rate of the EXP1XD was increased in firmware 3.3, to around 95kHz AFAIR. Most external stepper drivers are limited to 200kHz or lower anyway.
          • Marius Breuer
            Marius Breuer @T3P3Tony last edited by
            @t3p3tony my printer is intended to be a corexy, single Z-axis motor, single extruder. However lot's of addons are "in the works", so I'd tend to future-proof my machine by going with the Duet 3 6HC.
            For the 6XD: are we talking 2022, 2023?
            Thanks!
            T3P3Tony DHM-online 2 Replies Last reply Reply Quote 0
            • T3P3Tony
              @marius-breuer its on the drawing board but delayed. I very much want to have the design done and prototypes ordered within weeks, but I have wanted that for months now!
              www.duet3d.com
              • DHM-online
                DHM-online @Marius Breuer last edited by
                @marius-breuer Here it is! New restock on dhm-online.com
                Come and find your duet 3 new products: duet 3 6xd and more https://www.dhm-online.com/brand/14-duet3dduet 3 6XD_DHM.jpeg
                Compass DHM projects
                Customer Care
                Email: info@dhm-online.com | Phone: +39 049 2701149 | Office hours: Mon - Fri 09.00 - 12.00 / 15.00 - 18.00 | Web-links: https://linktr.ee/DHM_online
