    [Solved] [3.4-b5] Tool still not recognised as being loaded
    Beta Firmware
    • rjenkinsgb
      rjenkinsgb last edited by rjenkinsgb
      Edit - Nothing to do with the beta, it was a config file oddity that that should never have worked, but did not show itself until I started upgrading firmware/software, for some reason.
      The tool pickup problem still exists, exactly the same as with 3.4b4 in my previous thread here:
      https://forum.duet3d.com/topic/25434/firmware-3-4-beta-tool-pickup-problem.
      In brief, after picking up a tool, the machine does not recognise it has a tool loaded.
      All config etc. files unchanged from those in the previous thread.
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @rjenkinsgb last edited by
        @rjenkinsgb can you try it without T-1 in your tpre0.g?
        • rjenkinsgb
          I've now started again with a new install of the Pi SD card, after flashing the main board and tool board back to V3.3
          I put all the config files back on, expecting it to work as it did before I tried the beta versions - but the tool problem is still present!
          It's apparently nothing to do with the 3.4 betas.
          The only other things I updated whilst installing the beta version originally were the Paneldue 7i and the toolboard bootloader???
          Any ideas?
          Robert J.
