    New Setup Troubles
    • themonet
      themonet last edited by
      Hi! I'm way out of my depth when dealing with small electronics and firmware, so I'm sure it's a dumb problem I'm having. I've searched the forums and haven't seen anything that solves my specific problem.
      I'm trying to connect my New Duet 2 Wifi board to wifi for the first time. I'm at the M587 step, and I input my router name and password, and I don't get any error message, or an "ok".
      M552 SO
      ok
      WiFi module started
      M552
      WiFi module is idle
      ok
      M587 S"Swarm 2.4" P"swarmeffect"
      Above is exactly what I'm seeing, pasted from the terminal emulator.
      SO I don't know if I'm doing something wrong. Any help would be wonderful. Been at this for a couple hours googling and trying different things, but can't seem to solve it.
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @themonet last edited by
        @themonet
        Are you powering the board from the USB connection?
        themonet 1 Reply Last reply Reply Quote 0
        • themonet
          themonet @fcwilt last edited by
          @fcwilt Yeah, Plugged directly into my Mac.
          • droftarts
            droftarts administrators @themonet last edited by
            @themonet Looks like you used M552 SO, with an upper case 'o' not '0' ie zero.
            See this thread about someone having issues with SerialTools: https://forum.duet3d.com/topic/23545/mini5-wifi-set-up
            SerialTools is a bit finicky about input; you have to get the command right, without pressing delete or cursor keys. I think it sends each character to the Duet as you type them, rather than when you press return. If you navigate away from SerialTools to another application, and then back, in the middle of writing the command, it won't work. You should get an 'ok' when a command goes through correctly.
            Also, make sure you're using straight quotes, eg " rather than curly quotes, eg ”
