Connection issues between 6HC and Pi 3B
1.2k
  • undefined
    alastair1 @T3P3Tony
    @t3p3tony said in Connection issues between 6HC and Pi 3B:
    M98 P"0/sys/config.g"
    Error: M584: Board 121 received unknown msg type 6042
    Error: M350: Board 121 received unknown msg type 6042
    Error: M92: Board 121 received unknown msg type 6042
    Error: M906: Board 121 received unknown msg type 6043
    Error: M308: Board 121 received unknown msg type 6031
    Error: M950: Pin 121.out0 is not free
    Error: M307: Heater 1 not found
    Error: M143: Heater 1 does not exist
    Heater 1 is the bed and is direct from the duet, so don't worry about that.
    undefined 1 Reply Last reply 26 Oct 2021, 09:37 Reply Quote 0
    • undefined
      T3P3Tony administrators @alastair1
      @alastair1 please send M115 B121
      www.duet3d.com
      undefined 1 Reply Last reply 26 Oct 2021, 10:16 Reply Quote 0
      • undefined
        alastair1 @T3P3Tony
        M115 B121
        Thanks Tony! You are my saviour, it was actually running 3.1. I didn't realise I needed to run a M997 to get the firmware to update. Now its 3.3 and is extruding 🙂 Super satisfying to see the 1.2mm noodle.
        undefined 1 Reply Last reply 26 Oct 2021, 11:19 Reply Quote 1
        • undefined
          @alastair1 with everything working in a steady state then future stable->stable upgrades should upgrade all the expansion boards as well.
          www.duet3d.com
          21 out of 24
