    Solved Resume from pause doesn't respect previous feederate.
    CNC
    237
    • Zakm0n
      Zakm0n last edited by
      So, I'm running a custom pause and resume macro, but when I resume from pause, the feedrate is out of control. My file's feedrate is 75, but on resume, my XY movements seem to be at rapids speed. Gcode is as follows:
      Pause.g:
      G60 S1
      G54 (I work in G55)
      G0 Z100 (machine limit)
      G55
      Resume.g
      G0 R1 Z5
      G1 R1 Z0 F75
      G55 (just in case)
      fcwilt dc42 2 Replies Last reply Reply Quote 0
      • fcwilt
        fcwilt @Zakm0n last edited by
        @zakm0n said in Resume from pause doesn't respect previous feederate.:
        Pause.g:
        G60 S1
        G54 (I work in G55)
        G55
        Resume.g
        G0 R1 Z5
        G1 R1 Z0 F75
        G55 (just in case)
        Add F parameters to the G1 commands to set whatever speed you would like. F4500 would correspond to 75 mm/s.
        Zakm0n 1 Reply Last reply Reply Quote 0
        • Zakm0n
          Zakm0n @fcwilt last edited by
          @fcwilt
          The only G1 in this sequence has F75 for 75mm/min (I'm fine tuning feed rate with the speed slider.) That should carry over to the program g-code on resume.
          fcwilt 1 Reply Last reply Reply Quote 0
          • fcwilt
            @fcwilt
            The code in a print file usually has many, many F parameters setting the speed.
            It's likely that any speed you set is going to be quickly overridden by those changes.
            • Zakm0n
              @fcwilt This is a CNC mill, so there is one F called early in the cut. Regardless, the speed this thing is moving is downright dangerous. Even if the next line had a F parameter called, the remainder of the cut move after unpausing could cause catastrophic damage. Like I said, at no point should there be anything other than F75 through a pause and unpause, but yet, I'm seeing close to F6000.
              • fcwilt
                fcwilt @Zakm0n last edited by fcwilt
                Sorry - I keep forgetting the CNC section is here in this forum.
                Can you use M203 or M220 to limit the speed?
                • Zakm0n
                  @fcwilt M203 is my rapids speed. When I use G0 to call a move at max speed, that's the speed it runs at. M202 is not implemented in the firmware. G1 and G0 are modal, meaning you only have to have one line with G0/G1 and then every following line can have just coordinates to go to, just like the F parameter. In the 3d printer world, modal is called sticky I believe. So either my problem is that the lines after resume are treated as a G0, because they don't have a G command at the start of the line, or the F parameter is lost and the max is used. Either way, the firmware shouldn't behave this way, especially since the G1 R1 Z0 F75 should have both the G1 and the F75 held over as modal/sticky
                  fcwilt T3P3Tony 2 Replies Last reply Reply Quote 1
                  • fcwilt
                    @zakm0n
                    Got it.
                    To see if the behavior is related to G0 could you, as a test, code pause and resume with only G1, using the F parameter to obtain G0 speed?
                    And that M202 was a typo - it should have been M220.
                    • T3P3Tony
                      T3P3Tony administrators @Zakm0n last edited by
                      @zakm0n there was an issue with this in SBC mode in previous 3.4 betas that was fixed in the latest beta, if you are running SBC mode and an earlier beta of 3.4 please can you upgrade to 3.4b5 and see if the problem is fixed
                      www.duet3d.com
                      • Zakm0n
                        Zakm0n @T3P3Tony last edited by
                        @t3p3tony Sorry, forgot to mention I'm on a duet 2 wifi.
                        @fcwilt I'll do that and report back
                          dc42 administrators @Zakm0n last edited by
                          @zakm0n the move back to the original location from the place you moved the tool to in pause.g will be at a default speed; but when it resumes the job, it should go at the original speed it was using when the job was paused. Is that not happening?
                          • Zakm0n
                            Zakm0n @dc42 last edited by
                            @dc42 No, it's not. It's resuming at top speed in the cut. Here is a snippet of the code I'm running.
                            G55
                            M8
                            M3 S6000
                            G00 Z20
                            G00 X13.0734 Y315.6128
                            G00 Z-5.08
                            G01 Z-7.62 F125
                            X13.0607 Y312.7553
                            X13.8151 Y312.8518 Z-7.6327
                            X14.5161 Y313.1464 Z-7.6454
                            X15.1155 Y313.6138 Z-7.6606
                            X15.5702 Y314.2234 Z-7.6733
                            X15.8496 Y314.9295 Z-7.686
                            X15.9309 Y315.6864 Z-7.6987
                            X15.8115 Y316.4357 Z-7.7114
                            X15.4965 Y317.1292 Z-7.7267
                            X15.0114 Y317.7134 Z-7.7394
                            X14.3891 Y318.1502 Z-7.7521
                            X13.6728 Y318.4068 Z-7.7648
                            X12.9159 Y318.4652 Z-7.78
                            X12.1691 Y318.323 Z-7.7927
                            X11.4859 Y317.9877 Z-7.8054
                            X10.9144 Y317.4848 Z-7.8181
                            X10.4978 Y316.8498 Z-7.8308
                            X10.2641 Y316.1259 Z-7.8461
                            X10.2286 Y315.3664 Z-7.8588
                            X10.3937 Y314.6247 Z-7.8715
                            X10.7493 Y313.9516 Z-7.8842
                            X11.27 Y313.3979 Z-7.8969
                            X11.9177 Y313.0017 Z-7.9121
                            X12.6467 Y312.7883 Z-7.9248
                            X13.0607 Y312.7553 Z-7.9375
                            chrishamm 1 Reply Last reply Reply Quote 0
                            • chrishamm
                              chrishamm administrators @Zakm0n last edited by
                              @zakm0n Does a final G1 R1 at the end of the file fix it?
                              Duet software engineer
                              • Zakm0n
                                Zakm0n @chrishamm last edited by Zakm0n
                                @chrishamm like at the end of resume? To be clear, this is not the entire file, just the first couple lines.
                                  @zakm0n remove the G60 S1 command from pause.g. I think that command is causing the issue.
                                  Zakm0n 1 Reply Last reply Reply Quote 1
                                  • Zakm0n
                                    @dc42 spot on. It does exactly what I expect with that removed.
                                    • Topic has been marked as a question  dc42 dc42
                                    • Topic has been marked as solved  dc42 dc42
