    Mini5 BLTouch Z Endstop error
    • Mart1nS
      Mart1nS last edited by Mart1nS
      Ratrig coreXY VCore3. New build
      BLTouch does self check a startup
      Deploys and retracts correctly with M280 P0 Sx
      Deploys correctly when Z homing
      Triggering probe doesn't stop the bed
      Connected to IO_2, just using a temp extension for now until working and I'll crimp a 5pin connector on. Wiring looks right to me (White/Brown/Black/Yellow/Red - top to bottom)
      config,g
      M574 X1 S1 P"io1.in"
      M574 Y2 S1 P"io0.in"
      M574 Z1 S2
      ; BLTouch
      M950 S0 C"io2.out"
      M558 P9 C"io2.in" H5 F240 T10800 A1
      G31 P25 X-28.00 Y-13.00 Z0.90
      homez
      ; BLTouch
      M280 P0 S160
      M280 P0 S90
      G91
      G1 H2 Z5 F6000
      G90
      G1 X150 Y150 F10000
      G30
      G91
      G1 Z5 F100
      G90
      Mart1nS 1 Reply Last reply Reply Quote 0
      • Mart1nS
        Mart1nS @Mart1nS last edited by
        @mart1ns
        I suspected the extension cabling, so plugged the BLTouch directly into the board using the attached short leads. Same problem
        I tried a PINDA from my Mk3s. Wired into IO_3 and it worked fine. Z triggered as expected.
