    print timer restart after print ...
    Beta Firmware
    122
    • SIam
      SIam last edited by
      Copy from : https://forum.duet3d.com/topic/25605/dwc-print-timer-bug-oddity-and-cura-gcode-error
      When the print ends, the timer resets and starts counting down again.
      this Problem persists from firmware 3.3 up to 3.4.b5
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @SIam last edited by
        @siam Is that in standalone or SBC?
        Does it happen when the slicer time is greater than the print time?
        I haven't seen it happen on my machines and I use Cura
        SIam 1 Reply Last reply Reply Quote 0
        • SIam
          SIam @jay_s_uk last edited by
          @jay_s_uk said in print timer restart after print ...:
          Duet wifi 2 in stand alone
          mmhh the slicer time is on my machine always bigger as the real print time
          I use prusaslicer, but it will happen with cura too as you can see in the link at my first post
          • jay_s_uk
            @siam I tend to adjust the machine settings to match mine. In prusaslicer, if you change the flavour, the settings tab for all the speeds etc comes back and you can fill them all in. When you change back to reprapfirmware that settings tab disappears but it appears those speeds are still respected.
            I can usually get my slicer times to with 10 mins or so
            • SIam
              In my case this menu not appears, but I will look what is going wrong.
              In the meantime I have made a short video on this, you can see that the slicer time will be reset to the start time after the print
              https://kleinersonnenschein.eu/printtime.mp4
              jay_s_uk SIam 2 Replies Last reply Reply Quote 0
              • jay_s_uk
                @siam must be some sort of overflow of the slicer time that @chrishamm needs to look at that only occurs when the print takes longer than the slicer thinks it should.
                • SIam
                  Not in my case The slicer time was at ca 3 minutes and the print was finished
                  • SIam
                    SIam @SIam last edited by
                    @siam said in print timer restart after print ...:
                    found it 😄 the Machine limits are only showed if Marlin is selected
