    Solved cube
    169
    • sgk
      sgk last edited by
      Hello someone can tell me why my cube is half in normal cube?!Capture d’écran 2021-10-20 110812.png
      cosmowave 1 Reply Last reply Reply Quote 0
      • cosmowave
        cosmowave @sgk last edited by
        @sgk eventually your steps/mm are wrong?
        or you have a scale factor in the slicer?
        Mankati FSXT+, DeltaTowerV2, CBot3D
        sgk 1 Reply Last reply Reply Quote 0
        • sgk
          sgk @cosmowave last edited by
          @cosmowave here M92 X200,120 Y200,541 Z400 E686.5 ; Set steps per mm for Bondtech
          cosmowave 2 Replies Last reply Reply Quote 0
          • cosmowave
            @sgk steps/mm are machine specific. So i can not say if there is a fault!
            When you move z in dwc e.g. 10mm, does the machine move 10mm?
            • cosmowave
              @sgk said in cube:
              For what are the ",120" and ",541"? I'm not sure if a colon works in the configuration... you eventually should use a dot "."
              sgk 1 Reply Last reply Reply Quote 1
              • sgk
                @cosmowave I replaced the 8t z rods with 1204
                M92 X200,120 Y200,541 Z800 E686.5
                • cosmowave
                  @sgk i can't follow you....
                  It is working now?
                  • sgk
                    @cosmowave yes thank you 👍
