    Solenoid in 1LC board
    • Marcossf
      Marcossf last edited by
      Hi everyone,
      How can I drive a relatively small but powerfull solenoid in a printhead with the 1LC board rev. 1.0?
      Maybe could be use the hotend OUT0 pins than can drive 24v?
      Thanks!
      • T3P3Tony
        T3P3Tony administrators @Marcossf last edited by
        @marcossf please give the specifications of the solenoid you want to use.
        www.duet3d.com
        Marcossf 1 Reply Last reply Reply Quote 1
        • Marcossf
          Marcossf @T3P3Tony last edited by
          @t3p3tony Still don't know the specific model. It needs to be 10-15mm travel and about 5N force.
          Something like that:
          https://uk.rs-online.com/web/p/solenoides-lineales/1719575
          • T3P3Tony
            @marcossf the out0 pins can drive up to 5A at 24V so the solenoid you linked will be fine but you do need to add a flyback diode connected in parallel with the solenoid, cathode to positive side, anode to negative side.
            www.duet3d.com
            • Marcossf
              @t3p3tony Ok, thanks!
