    BLTOUCH ERRO ON 3.4.0beta5
    Firmware installation
    • josegerdes
      josegerdes last edited by
      I have Duet 3 Wifi Mini ( plus i think ) and BLTOUCH COMMANDS ARE NOT WORKING... All updated...
      https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.0beta5
      i had to update because my sensorless was with a bug.
      • T3P3Tony
        T3P3Tony administrators @josegerdes last edited by
        @josegerdes please do the following:
        1. explain what is not working with your BL touch
        2. Post your config.g, retractprobe.g, deployprobe.g using the </> command in the text formatting for each one when you post them on here so we can view them easily.
        No need to should with the all capital letters!
        www.duet3d.com
        • josegerdes
          josegerdes last edited by josegerdes
          @t3p3tony Sory about Captal letters! Long time i dont use forums. I like this community a lot.
          So my bltouch its a bit strange...
          these commands i got it working.. i was using like
          M280 P3 S10 I1 ; deploy - it was wrong
          M280 P0 S10 ; deploy
          M280 P0 S90 ; retract
          M280 P0 S120 ; test mode
          M280 P0 S160 ; clear test mode or error condition
          but i am having other error, sometimes my bltouch get stuck up and then do a erro and i cant reset, its like the magnet its so strong
          @T3P3Tony
          Deploy
          ; deployprobe.g
          ; called to deploy a physical Z probe
          ; generated by RepRapFirmware Configuration Tool v3.3.4 on Fri Oct 15 2021 18:08:53 GMT-0300 (Horário Padrão de Brasília)
          M280 P0 S10 ; deploy BLTouch
          Retract
          ; retractprobe.g
          ; called to retract a physical Z probe
          M280 P0 S90 ; retract BLTouch
          Config
          ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
          M550 P"José Arthur's Printer" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0.0 S1 D3 V60 ; physical drive 0.0 goes forwards
          M569 P0.1 S0 D3 V60 ; physical drive 0.1 goes forwards
          M569 P0.2 S0 ; physical drive 0.2 goes forwards
          M569 P0.3 S1 ; physical drive 0.3 goes forwards
          M569 P0.4 S0 ; physical drive 0.4 goes forwards
          M584 X0.0 Y0.1 Z2:4 E0.3 ; set drive mapping
          M350 X32 Y32 Z32 E32 I1 ; configure microstepping with interpolation
          M92 X160.00 Y160.00 Z3200.00 E830.00 ; set steps per mm
          M566 X900.00 Y900.00 Z100.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X210 Y215 Z200 S0 ; set axis maxima
          M574 X1 S3 ; configure sensorless endstop for low end on X
          M574 Y1 S3 ; configure sensorless endstop for low end on Y
          M574 Z1 S2 ; configure Z-probe endstop for low end on Z
          M915 X S4 F0 R0 ; Set X axis Sensitivity
          M915 Y S4 F0 R0 ; Set X axis Sensitivity
          M950 S0 C"io3.out" ; create servo pin 0 for BLTouch
          M558 P9 C"^io3.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 X15:195 Y0:160 S20 ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
          M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
          M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
          M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
          josegerdes droftarts 2 Replies Last reply Reply Quote 0
          • josegerdes
            josegerdes @josegerdes last edited by josegerdes
            @T3P3Tony SelfTest work but probe not work, make the bltouch get stuck some times.. @dc42
            • droftarts
              droftarts administrators @josegerdes last edited by
              @josegerdes said in BLTOUCH ERRO ON 3.4.0beta5:
              Remove ^ from pin name. Pull up resistor should not be set. See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
              So:
              M558 P9 C"io3.in" H5 F120 T6000
              If the probe doesn’t deploy with M401 and retract with M402 (your deployprobe.g and retractprobe.g look correct), check your wiring, particularly the orange wire, which controls the pin deployment.
