RRF configuration file mirroring and management
I've been using RRF for the past year, it's great. Configuration management is a little bit of a pain, edit it in DWC or by pulling out the SD card and plopping it into my PC. This is a feature where having SBC-mode is an advantage.
But, there's no killer feature for SBC-mode, so I refuse to use it
-Instead of that, I wrote a new tool that runs on any local machine that has python2: that would include macOS, Linux and some Windows computers (but untested on macOS and Windows).
What it does:
- Initially downloads all files from a DWC URL under /sys and /macros to a specified directory (
-m URL
-d DIRECTORY
) - Creates a metadata file that remembers the DWC URL and digests of all files downloaded
Now you have a local copy of your configuration, but that's not so useful yet, on top of that you can operate in the mirrored configuration folder, there are options to:
- See if there are any local modifications by checking for differences in digests (run without arguments)
- Refresh and download configuration from RRF again (
-r
option) - Edit files locally, using your choice of editor; I prefer VIM
- Upload changed local files to RRF (
-u
argument)
Limitations:
- Passwords set in RRF will prevent this from working
- Local modifications will be overwritten without notice with
-r
- Only
/sys
and/macros
directory trees are synchronized - There is no diffing to determine difference
- However, there is nothing to prevent the use of
git
or other SCM to manage configuration and tracking of changes.
Currently I have it uploaded into a gist, and perhaps it will move into a repo if it gets enough traction:
https://gist.github.com/pfn/9f28b1e8d70a9e0d1182c77af177161cHope someone finds this useful!
@droftarts I never knew about this before (not the specifics anyhow). However, upon browsing rfm, the UI seems very different. In my case, I'm looking for a very "git/mercurial/other-dvcs"-like workflow where I can see what my file status looks like at any given moment with minimal/no configuration other than an "init" (
-m ... -d ...
) command.rfm looks great on its own as a general-purpose tool to fetch/upload files from RRF.
This tool itself is only intended to work with files under /sys and /macros
@pfn thanks for this. I have moved the thread to the third party software category so its less likely to get lost in the volume on General Discussion.
@pfn you may also find this interesting https://github.com/adammhaile/rrgit.
I've added @pfn 's RRF configuration file mirroring and management tool, and @adammhaile 's rrgit to https://duet3d.dozuki.com/c/Community_Projects
@dc42 that's pretty nice as well, thanks for linking. the suggestion to use M38 is also good, but ultimately unusable because of race conditions in getting rr_gcode/rr_reply properly aligned.
