    Configuring tool board(Push Pull) remote extruder Issue
    Using Duet Controllers
    • aprz
      aprz last edited by
      I'm wondering if the issue I'm having is due to incorrect Gcode or if the duet software doesn't work with the configuration I'm trying to use on the 3HC boards. I have a tool board connected to tool 0 on driver 20.0 with a direct drive extruder and a remote stepper motor on the opposite end of the Bowden tube to push filament. I was configuring the remote stepper motor to driver 1.2(3HC board) and was having issues where it would seem to cause the y stepper motors(all y stepper motors are on the 3hc board) to become unsynchronized and they would begin to lose steps and make noise. I ended up switching the remote extruders driver from 1.2(3HC board) to 0.4 (Main Board) now its working but would like to add more remote stepper motors for other tools in the future. Can someone inform me on the software limitations, I couldn't find anything specifically on this. thanks.
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.2 on Tue Sep 21 2021 11:41:45 GMT-0700 (Pacific Daylight Time)
      G90                                                     ; send absolute coordinates...
      M83                                                     ; ...but relative extruder moves
      M550 P"Duet 3"                                          ; set printer name
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      ;M552 P0.0.0.0 S1        ; enable network and acquire dynamic address via DHCP
      ;M586 P0 S1        ; enable HTTP
      ;M586 P1 S0        ; disable FTP
      ;M586 P2 S0        ; disable Telnet
      M569 P1.2   S0                                                   ; X axis physical drive 0.4 goes forwards
      M569 P2.2   S0                                                   ; X axis physical drive 0.5 goes forwards
      M569 P2.0   S0                                                   ; Y axis physical drive 2.0 goes forwards
      M569 P2.1   S0                                                   ; Y axis physical drive 2.1 goes forwards
      M569 P1.1   S1                                                   ; Y axis physical drive 1.1 goes forwards
      M569 P1.0   S1                                                   ; Y axis physical drive 1.3 goes backwards
      M569 P0.0   S0                                                   ; Z axis physical drive 0.0 goes forwards
      M569 P0.1   S0                                                   ; Z axis physical drive 0.1 goes forwards
      M569 P0.2   S0                                                   ; Z axis physical drive 0.2 goes forwards
      M569 P0.3   S0                                                   ; Z axis physical drive 0.3 goes forwards
      M569 P20.0  S0                                                   ; Tool 1 physical drive 20.0 goes forwards
      M569 P21.0  S1                                                   ; Tool 2 physical drive 21.0 goes forwards
      M569 P0.4   S0                                                   ; Tool 2 physical drive 21.0 goes forwards
      M584 X1.2:2.2 Y2.0:2.1:1.1:1.0 Z0.0:0.1:0.2:0.3 E20.0:21.0:0.4   ; Four Z motors connected to driver outputs Z axis
      M671 X-30:-30:890:890 Y-30:1150:1150:-30 S3                      ; leadscrews at rear left, front left, front right, rear right (connected to Z)
      M208 X0:845   Y0:890                                             ; X carriage moves from 0 to 870, Y bed goes from 0 to 870
      M350 X4       Y4       Z16        E16:16:16  I1                  ; configure microstepping with interpolation
      M92  X40.00   Y40.00   Z3200.00   E837.00:837.00:830.00          ; set steps per mm
      M566 X110     Y110     Z270.00    E7000.00:7000.00:7000.00       ; set maximum instantaneous speed changes (mm/min)
      M203 X7250.00 Y7250.00 Z350.00    E10000.00:10000.00:10000.00    ; set maximum speeds (mm/min)
      M201 X115.00  Y115.00  Z290.00    E8000.00:8000.00:8000.00       ; set accelerations (mm/s^2)
      M906 X2500    Y2500    Z2100      E550:550:550  I20              ; set motor currents (mA) and motor idle factor in per cent
      M84  S20                                                         ; Set idle timeout
      M208 X0   Y0   Z0    S1                                          ; set axis minima
      M208 X845 Y890 Z780  S0                                          ; set axis maxima
      ; Filament sensors
      M591 D0 P1 C"20.io1.in" S1                                       ; filament monitor connected to pin 121.io1
      M591 D1 P1 C"21.io1.in" S1                                       ; filament monitor connected to pin 121.io1
      ;Extra sensor
      M308 S10 Y"mcu-temp" A"MCU"
      M574 X1 S1 P"2.io2.in"                                    ; configure active-low endstop for low end on X via pin 2.io2.in
      M574 Y1 S1 P"1.io2.in"                                    ; configure active-low endstop for low end on Y via pin 1,io2.in
      M558 P8 C"!21.io0.in" H3 F300                            ; set Z probe type to unmodulated and the dive height + speeds
      G31  P500 X0 Y0 Z-0.28                                   ; set Z probe trigger value, offset and trigger height
      M557 X60:820 Y60:820 S65                                   ; define mesh grid X/Y and probe spacing
      M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950           ; configure Bed sensor 1 as thermistor on pin temp0
      M950 H0 C"out0" T0                                            ; create bed heater output on out0 and map it to sensor 1
      M307 H0 R0.224 C219.6 D7.78 S1.00 V24.1                       ; PID auto tune results for Tool 1 bed heater
      M140 H0                                                       ; map heated bed to heater 1
      M143 H0 S120                                                  ; set temperature limit for heater 1 to 120C
      M308 S1 P"20.temp0" Y"pt1000" A"Tool 0"                       ; configure sensor 0 as thermistor on pin 20.temp0
      M950 H1 C"20.out0" T1                                         ; create nozzle heater output on 20.out0 and map it to sensor 0
      M307 H1 B0 R1.858 C109.4 D2.96 S1.00 V23.6                    ; PID auto tune results for Tool 0 Titan Aqua 1.75
      M308 S2 P"21.temp0" Y"pt1000" A"Tool 1"                       ; configure sensor 0 as thermistor on pin 20.temp0
      M950 H2 C"21.out0" T2                                         ; create nozzle heater output on 20.out0 and map it to sensor 0
      M307 H2 B0 R1.717 C105.7:98.6 D2.95 S1.00 V23.9               ; PID auto tune results for Tool 0 Titan Aqua 1.75
      ;fan
      M950 F0 C"out8" Q250        ; create fan 0 on pin out8 and set its frequency
      M106 P0 T115 S0.10 H1:2 C"Radiator Fan"                                                    ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"20.out2" Q250        ; create fan 1 on pin out9 and set its frequency
      M106 P1 T205 S0.10 H1 C"Titan Aqua 1.75 T1 Hot end Fan"                                    ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"21.out2" Q250        ; create fan 0 on pin out8 and set its frequency
      M106 P2 T205 S0.10 H2 C"Titan Aqua 1.75 T2 support material Fan"                           ; set fan 0 value. Thermostatic control is turned on
      M563 P0 S"Titan Aqua 1.75" D0:2 H1 F0:1                         ; define tool 0
      M567 P0 E1.00:1.00                                              ; Mix drive E0 and drive E2
      G10  P0 X0 Y0 Z0                                                ; set tool 0 axis offsets
      G10  P0 R0 S0                                                   ; set initial tool 1 active and standby temperatures to 0C
      M563 P1 S"Titan Aqua 1.75 support" D1 H2 F0:2                   ; define tool 1
      G10  P1 X-15.4 Y0 Z0                                            ; set tool 2 axis offsets
      G10  P1 R0 S0                                                   ; set initial tool 1 active and standby temperatures to 0C
      T0 ; select first tool
      o_lampe dc42 2 Replies Last reply Reply Quote 0
      • o_lampe
        o_lampe @aprz last edited by
        @aprz You are mixing E0:2 with mixing ratio 1:1, but the steps/mm are different? (837 vs 830)
        Wouldn't you be better off when you'd wire both steppers to the same driver? (in series, as it was frequently done for dual Z motors )
        aprz 1 Reply Last reply Reply Quote 0
          dc42 administrators @aprz last edited by
          @aprz what firmware versions are you running on the main board, the 3HC and the expansion board? Use M115 B# to check (where # is the CAN address of the board).
          • aprz
            aprz @o_lampe last edited by aprz
            @o_lampe The steps are different due to the gear ratios being different on each motor. I was going to try to run the motors on the same driver that's on the tool board but I just didn't want to run the wires from the tool board that's on the extruder to the remote stepper motor and have extra wires running from inside the print chamber. Also the peace of mind knowing I wont push the driver on the tool board too hard, which is something I didn't want to worry about since it can only use up to 1.6A. but good point I did consider that.
            • aprz
              aprz @dc42 last edited by
              @dc42 Here's the response I got, looks like all boards are running on the same firmware.
              m115 b20
              Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
              m115 b21
              m115 b1
              Duet EXP3HC firmware version 3.3 (2021-06-15 16:12:41)
              m115 b2
              m115 b0
              FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-06-15 21:45:56
