    Duet Magnetic Sensor false "positive" with PA
    Filament Monitor
    141
    • A Former User
      Hello, I'm using two original magnetic sensors. Using pressure advance (PLA o PETG is the same) it very very oftenly gous in pause for low movements....I see that the minum value read that causes the pause goes from 3% to 20% so the sensors are absolutely unuseful...I'm really upset because I've paid a "lot" of money for the sensors and I've waited almost two months for having them both....have someone experienced the same issue with PA? Theese are the values during the print:
      M591 D0
      Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 24.78mm/rev, allow 20% to 130%, check every 3.0mm, version 3, mag 129 agc 65, measured sensitivity 25.02mm/rev, min 100% max 101% over 15.5mm
      As I said I can't print anthing with PA but I can't give up PA....I'm starting to think to replace the sensors with two commons mechanical endstops but this fact really upsets me
      Anyone else experiencing the same issue with PA?
        dc42 administrators @Guest last edited by
        @thedragonlord please post a photo showing the filament monitor, the extruder drive, and the tubing between them.
        A Former User 1 Reply Last reply Reply Quote 0
        • A Former User
          A Former User @dc42 last edited by
          @dc42 said in Duet Magnetic Sensor false "positive" with PA:
          here they are:
          Is there something wrong?
          Thanks
            dc42 administrators @Guest last edited by dc42
            @thedragonlord that looks good. Please make the GCode file you are trying to print available on a file sharing site, and post your config.g file. Also post the results of sending M591 D# (where # is the extruder number) so that we can check the reported AGC values.
            A Former User 2 Replies Last reply Reply Quote 0
            • A Former User
              A Former User @dc42 last edited by A Former User
              Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 24.78mm/rev, allow 20% to 130%, check every 3.0mm, version 3, mag 131 agc 67, measured sensitivity 24.61mm/rev, min 16% max 121% over 1655.2mm
              I've already done it in a previous post of mine but here they are again:
              take_snapshot_at_layer_change.g print_tpu_pressure_advance.g print_start_gcode.g print_pla_pressure_advance.g print_petg_pressure_advance.g print_end_gcode.g pressure_advance_at_layer_change.g magnetic_filament_sensors.g layer_change_actions.g config.g
              Theese are all my custom g files and the config.g
              here's the gcode (but it happens with ALL the gcodes regardless the material):
              GTS3D PLA Calibration Cube T0__PLA GTS3D_0.2000mm.gcode
              • A Former User
                Just not to throw away the money, is there a way to make it work "simulating" a simple mechanical switch endstop? If I set R0:130 in the M591 command what would it happen?
                • T3P3Tony
                  T3P3Tony administrators @Guest last edited by
                  @thedragonlord there is a bit of duplication going on with the other thread where we are discussing this:
                  https://forum.duet3d.com/topic/25271/rotating-magnetic-sensor-keeps-pausing-printer/38
                  www.duet3d.com
                  • A Former User
                    A Former User @T3P3Tony last edited by
                    @t3p3tony said in Duet Magnetic Sensor false "positive" with PA:
                    I apologize, you're right. Is it possible to close this thread?
                    • T3P3Tony
                      @thedragonlord yep locked, we can keep the conversation in the other thread
                      www.duet3d.com
