    M557 Exclude centre of polar bed from mesh definition
    Firmware wishlist
    • CNCModeller
      CNCModeller last edited by
      Hi All,
      I want to prevent the mesh level routine from trying to mesh the centre of my polar printer. Is there any way to exclude this when defining the mesh.
      Ideally I'd like to set custom mesh points so it meshes by using several concentric rings, but it looks like custom meshes aren't supported any more?
      Using the M557 R method just appears to create a Cartesian meshes inside the defined radius.
      Any constructive thoughts would be much appreciated.
      All the best.
      Barry M
      Polar Printer Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      Wanhao D5S & K40 Laser, Duet2 TBD
      https://www.youtube.com/CNCModellerUK
      • T3P3Tony
        T3P3Tony administrators @CNCModeller last edited by
        @cncmodeller currently defining custom mesh patterns is not supported so have moved this post to the firmware wishlist.
        www.duet3d.com
        CNCModeller 1 Reply Last reply Reply Quote 0
        • CNCModeller
          CNCModeller @T3P3Tony last edited by
          Ok thanks @t3p3tony
          Wanhao D4S: Duet2
            dc42 administrators @CNCModeller last edited by dc42
            @cncmodeller that should already be taken care of by function IsReachable in file PolarKinematics.cpp. Any point that is less than the minimum radius from the centre (the first R parameter in the M669 command) should not be probed.
            • CNCModeller
              CNCModeller @dc42 last edited by CNCModeller
              @dc42 said in M557 Exclude centre of polar bed from mesh definition:
              @dc42 Ahh ok that makes sense. I've been using min R as zero since I never change it from when I was tramming in the printer. I've now set it to 50mm all seems good.
              Many thanks
              Barry M
              Wanhao D4S: Duet2
