    Odd Magnetic Sensor Results
    • NightLonk42
      NightLonk42 last edited by
      I've been getting some....very odd results when trying to configure the magnetic filament sensor. Any ideas?
      The min/max are always at these results, no matter how much prints
      Duet3D rotating magnet filament monitor v3 on pin 121.io1.in, disabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 132 agc 78, measured sensitivity infmm/rec, min 2147483647% max 2147483647% over 99.1mm
      dc42 T3P3Tony 2 Replies Last reply Reply Quote 0
        dc42 administrators @NightLonk42 last edited by dc42
        @nightlonk42 which version of RepRapFirmware are you using, and on which Duet?
        My guess is that filament motion is not causing the magnet to rotate.
        • T3P3Tony
          T3P3Tony administrators @NightLonk42 last edited by
          @nightlonk42 with the sensor assembled you should be able to feel the magnet rotates freely when manually running some filament through (by hand to feel the force). if you make a small dot on the part of the assembly that is visible on the back you can observe if the magnetic assembly is rotating freely.
          www.duet3d.com
