    Fan 12v the mainboard duet3d wifi
    102
    • sgk
      sgk last edited by
      Hello friends.
      Question can we put a 12v layer fan directly? I read yes and no !!!!!Screenshot_20211027_135817.jpg Screenshot_20211027_140011.jpg
      cosmowave T3P3Tony 2 Replies Last reply Reply Quote 0
      • cosmowave
        cosmowave @sgk last edited by
        @sgk If you have a 24V supply, you will need a stepdown converter to connect the fan.
        Mankati FSXT+, DeltaTowerV2, CBot3D
        • T3P3Tony
          T3P3Tony administrators @sgk last edited by
          @sgk the image you posted shows a 24V-12V converter being fed into the fan supply select central pin on the Duet 2. this provides 12V on the fan pins.
          www.duet3d.com
          • sgk
            sgk last edited by
            Excuse me, I'm a novice, is the mainboard 24 or 12 v? Because when I install fans of 24 it works and 12v also then I am lost.
            cosmowave 1 Reply Last reply Reply Quote 0
            • cosmowave
              @sgk You can power the Duet Board with 12V or 24V...
              It's depending on your power supply.
              sgk 1 Reply Last reply Reply Quote 0
              • sgk
                sgk @cosmowave last edited by
                @cosmowave OK, thanks.
                But then why when I plug in a 12v and 24v fan both work.
                I have a 24v output power supply
                • T3P3Tony
                  @sgk a 12V fan may work plugged into 24V but wont last long. a 24V fan will often spin when plugged into 12V but will be spinning much slower.
                  www.duet3d.com
                  • sgk
                    sgk @T3P3Tony last edited by
                    @t3p3tony yes OK thanks very much 👍😃
