    Polar Coordinates
    Using Duet Controllers
    • that guy E
      that guy E last edited by
      I am looking to use a Duet to run a custom lathe. I found the wiki on setting up a polar printer, which is helpful. I was wondering if its possible to specify which motor(s) are being used for each axis like you would a cartesian printer or core XY. I don't see any reference to this in the M669 outline.
        dc42 administrators @that guy E last edited by
        @that-guy-e you specify which motors drive which axes in the M584 command. In a polar printer, the X motor defined in M584 drives the radial head and the Y motor drives the turntable.
        that guy E 1 Reply Last reply Reply Quote 0
        • that guy E
          that guy E @dc42 last edited by
          @dc42 thank you for the quick response. I completely over looked that.
          Am I locked into using X for the radial component or could I assign that as Z?
          • rjenkinsgb
            rjenkinsgb last edited by
            The convention for lathes and vertical borers is that the spindle axis is Z and the radial axis is X. There is no Y axis.
            With two tools, the second tool movement parallel to Z is W and parallel to X is U.
            If you use the spindle / chuck for rotary positioning, then the angular setting is normally C axis
            If you want to keep compatibility with commercial machines, I'd suggest staying with those axis names.
            Robert J.
            Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
            • that guy E
              @rjenkinsgb Appreciate the info, reconsidering my original plan
