    Connect Wlan AP directly to the Duet 3 6HC
    • Dogma2k
      Dogma2k last edited by
      Can I connect an AP to this 5V connection?
      The AP should need 5V / 1A (will probably be a little less).
      In the description of the 6HC it says that up to 3A are possible.
      Or could I also connect the AP to the USB port to get the voltage from there?
      • T3P3Tony
        T3P3Tony administrators @Dogma2k last edited by
        @dogma2k that connection is external 5V input only. Also the USB port is for 5V input only.
        There is a 5V output on v1.01 and earlier MB6HCs: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_5V
        Designed to power a SBC like a raspberry pi.
        Be sure that the AP won't overload it, even at startup. Generally we would recommend powering external devices from there own power supply.
        www.duet3d.com
