    delete
    • BLV
      BLV last edited by BLV
      delete 🙂
      PCR 1 Reply Last reply Reply Quote -1
      • PCR
        PCR @BLV last edited by
        @blv which extra Performance?
        • Tinchus
          Tinchus last edited by
          Nice, but I have to tell you a couple of things: that machine is not running at 500 mm/2. You set it to run at 500 mm/2. But the geometry you are printing doesnt allow the machine to reach that speed, so basocally you are not printing a t that speed. Im very sure of that because my machine if I make a video print the same as your video, and Im using 200 mm/s. so basically we have the same (and my accel is 8500)
          If you really print at 500 mm/2, looking at your extruder I can tell you you wont be able to print, you just dont have the extrusion capability.
          And regarding klipper... well, there are some nice reports, but I have used it and when facing complex or high quality mesh, is trash.
          I prefer reprap all the time. It is more powerfull and who says this is somebody who have used marlin, klipper and reprap. Im still using the duet reprap firmware and still discovering how much options I can get from it,
          BLV 1 Reply Last reply Reply Quote -1
          • BLV
            BLV @Tinchus last edited by BLV
            This post is deleted!
            Tinchus A Former User 2 Replies Last reply Reply Quote 0
            • Tinchus
              Tinchus @BLV last edited by
              @blv there is no need to teach formulas or motion theroy, at least to me, Im a senior mechanical engineer, I guess I have those topics very clear. So Im pretty sure you can post your slicer profile, your config, and the STL so we can all see the sizes involved and it will be very simple to demostrate what I said is correct. But we can also do very super quick calulations looking the video: the size of the object is aprox 12 cms long. I has a soft cuve too. so lets say that segment is a real 15 cms as much it it is straight? If you print at 500 mm/s that means we should be watching your printhead cover those 15 cms in aprox 1/33 of a second without taking into consideration the acceleration. If we take into consideration the accel of 9000 you will reach something around 300 mm/s of max speed AND ONLY for a fraction of the path. Im dpoing all these calculation by my eye so I might be wrong in 20/50 mm/s max error.
              And Im still not taking into account your jerk settings.
              And this is the speed you get in your longest path, the rest of your STL model wont get even half of the calculated speed I have mentioned.
              So...
              And Im not fan of nobody. I use what I considere that covers my needs. I have used klipper. It is based on python, python uses an interpret to work. That means an extra layer between klipper and the processor. So it works very nive, but no software till today is as fast as a well C++ / C code is working directly with the processor... Or have you ever seen an OS written in python 😉 ?
              The firmware duet is working on is really powerful, enough for me moving from marlin.
              But hey... if you are fine with klipper, OK! keep using. You have to use whatever covers your needs man.
              Also I think it would be usufull if you clear what you mean with "extra perfomance", it would be a good way to contibute here to the developers.
              • A Former User
                A Former User @BLV last edited by A Former User
                1 Reply Last reply Reply Quote 4
